Question about Compaq Presario M2000 Notebook
Dark screen/ large font size in explorer
I have two problems with my compaq.  First, the screen has become very dark.  I changed the graphic colors to makeit a bit lighter but the screen is not the way it used to be.  Is there a simple fix that I can do?  Second, when I use internet explorer, the font is abnormally large.  I have changed the text size to the smallest setting but on some websites, the text is still huge.  Is there a way that I can fix this?  Are the two problems related in anyway since they relate to a screen.
  • 1,006 Answers
Re: dark screen/ large font size in explorer - Compaq Presario M2000 Notebook PC Laptops
Try to re-install windows of FORMAT IT!!!
Posted on Oct 26, 2007
0 characters
3 Points
How can I change my font size?
Go to your desktop opening screen. Place your cursor on a blank area. Click the right button on your mouse. Click on the display properties then on font size. This will change the default size. Check out your applications and see if you like it. You may need to change your screen size to something like 800 x 600. This can be a LOT oif work.
Aug 07, 2014 | HP Compaq 6720s Laptop
How do you get your computer screen back to normal size
You can right click on a empty space on the desktop then click properties. When the Desktop Properties window opens click the Appearance tab. Go down to the font size and you can change it to normal, large or extra large. Normal is what it should be.
You can also get there by going into the Control Panel and changing the Font size on the display. Click Start/Control Panel and look for Display or Appearance and Personalization. Open the display, click the Appearance tab and change the Font Size.
If that don't do what you are looking for you can click the Settings tab on the display to change the Screen Resolution. The higher the resolution, the smaller the icons and therefore the more you will get on the screen.
May 12, 2012 | PC Laptops
Reduce screen font size
your computer screen resolution is very high. Right click on desktop and go to Properties/Personalize option and then click on display and change the screen resolution according to your wish.
Nov 16, 2011 | Dell Latitude D410 Notebook
My font on my facebook site is huge and i cannot minimize it
If you have a mouse with a wheel and are using any of the below browsers, you can quickly and easily increase and decrease the size of your fonts in your browser by holding down the Ctrl key, and while continuing to hold down the key, move the mouse wheel up or down.
For Internet Explorer:
To increase, decrease, or change the default font in Microsoft Internet Explorer, follow the below steps.
  1. Open Microsoft Internet Explorer.
  2. Click Tools.
  3. Click Internet Options.
  4. Within the Internet Options window, click the Fonts button at the bottom of the General tab.
  5. Within the fonts window you can adjust the default font used in Internet Explorer. If you need additional font options, you can adjust how fonts are used by clicking the Accessibility button in the General tab.
Note: Microsoft Internet Explorer also supports the tip mentioned at the beginning.
For Mozilla Firefox:
To increase, decrease, or change the default font in Mozilla Firefox, follow the below steps.
  1. Open Mozilla Firefox.
  2. Click Tools.
  3. Click Options.
  4. Within the Options window, click the Content button.
  5. Within the content section you will be able to specify the default font type as well as the font size. In addition to being able to change these two settings, you can also click the Advanced button and get many more settings, such as the resolution and the minimum font size to use.
Note: Mozilla Firefox also supports the tip mentioned at the beginning.
For Netscape:
  1. Open Netscape.
  2. Click Tools.
  3. Click Options.
  4. Within the Options window, click the Fonts & Colors button.
  5. Once within the Fonts & Colors window you can adjust the different fonts including, the colors, resolution, and minimum font size.
Note: Opera also supports the tip mentioned at the beginning.
For Opera:
  1. Open Opera.
  2. Click Tools.
  3. Click Preferences.
  4. Within the Preferences window, click the Web pages tab.
  5. Once in the Web pages tab you will be able to adjust the fonts used. If you need more settings to adjust your fonts or font size, click the Advanced tab and click the Fonts option for several dozen additional changes that can be made to the fonts.
Mar 21, 2011 | PC Laptops
I want to know how to change my text size because the words are o big
Go to your control panel in the start menu. Search "Display" in the search box and then click Display when it appears. Then choose to expand things by 125% or 150% with "medium" or "large" respectively.
Mar 13, 2011 | PC Laptops
I hit some button while on AOL...and my screen font size changed to LARGE print...How do I change it back?...have gone to my PC settings, etc...cannot fix it...?
I"m assuming you're using Internet Explorer. On the menu bar go to "View" then go to "Text Size" and choose the size of text you want on your web pages.
Oct 31, 2009 | Dell Inspiron 6400 Notebook
Internet Explorer
Override website font and color settings Go to -Internet Options
If you want to have the fonts and colors you specify in Internet Explorer to be used for all websites, regardless of the fonts that have been set by the website designer, follow these steps.
  1. In Internet Explorer, click the Tools button, and then click Internet Options.
  2. On the General tab, click Accessibility.
  3. Select the Ignore colors specified on webpages, Ignore font styles specified on webpages, and Ignore font sizes specified on webpages check boxes, and then click OK twice.
Jul 13, 2009 | Dell Inspiron 1420 Notebook
All icons and text appear very large and dull
This could be two problems right click on the main desktop computer screen go down to properties and click on that, then go to settings Change the screen area of your computer to a more also click on advanced and change the font size to small that should solve the problem you can also look at views under explorer to small
Jan 22, 2009 | Toshiba Satellite A10-S100 Notebook
Page size too large for my screen.
I have windows xp home edition and would like to shrink my page to screen size without reducing font size.
May 24, 2008 | Compaq Presario 1800T Notebook
Compaq Presario M2000 Notebook Logo
101 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
