FixYa.com
Tags:
NEC SuperScript 1260 Laser Printer
Setting up NEC 1260 laser printer with Redhat 5.2
By Lizzy - usenet poster
I just installed Redhat 5.2.  I have an NEC 1260 laser printer, which of
course is not listed.  I read in my printer manual that the printer supports
the HP Laserjet II language, so I have set it up as that.  It printed a test
page, but I am wondering about if there are more compatible printer drivers
out there?
Steve
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
 >Hi,
 >I just installed Redhat 5.2.  I have an NEC 1260 laser printer, which of
 >course is not listed.  I read in my printer manual that the printer supports
 >the HP Laserjet II language, so I have set it up as that.  It printed a test
 >page, but I am wondering about if there are more compatible printer drivers
 >out there?
It's not listed because the printer control language is proprietary.
You're using the lower-resolution emulation mode and that's the best
that can be done until the printer manufacturer tells someone other
than Microsoft how to control their printers.
Bob T.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
"Robert J. Hansen" <rjhan @inav.net> writes:
The problem is as stated in the Printing HOWTO:
  NEC SuperScript
     NEC's series of low-cost laser printers provides both PCL and
     PrintGear support and are generally attractive printers.
     Unfortunately, in many of these models, the PCL support is for
     PCL level 4.5, which allows printing at only 300dpi. PCL levels
     5e, 6, and above do allow for 600dpi output.
Unfortunately, I am not aware of any support for "Adobe PrintGear"
printers in Ghostscript.  The 1260 does appear to have a Postscript
option which would probably solve the problem, although not for free.
Grant Taylor - gtaylor@picante<dot>com - http://www.picante.com/~gtaylo r/
 Cellphone information: http://www.picante.com/~gtaylo r/cell/
 Libretto information:  http://www.picante.com/~gtaylo r/portable/
Solution #3
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
"More compatible"?  If it's compatible with PCL (HP's version of
PostScript), then you're running it in a mode that it supports fully, so
where's the problem?
If your printer stops working, or prints funny, or you one day wake up
to find your printer possessed by the spirit of Alan Turing, then you've
got a problem.  Until then, just enjoy your printer.  :)
To the best of my knowledge nobody's written a NEC-1260 driver.  If you
want one, you're probably going to have to write it yourself.
Can you Help with these Printers problems?
Printers
cannot install my lexmark z12
cannot install my lexmark z12... Answer This...
Printers
printer issues
Hi there! My printer is taking... Answer This...
Printers
Distinctive Ring Setup
I have programed my Samsung AIO... Answer This...
Printers
A menu keeps popping up
A menu keeps popping up telling... Answer This...
Driver for use with Vista and...
Need a Driver Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
