Question about GE 24 in. GLD6200L Built-in Dishwasher
GLD6200 NOISY We have above unit approx. 2 years. It just started having a "rumbling noise" when running (all cycles}. The floor even vibrates mildly. It works fine just annoying - it used to be very quiet. Everything I know how to check seems fine. Do I need a repairman ?
  • 283 Answers
The sound is almost always caused by a worn docking cone “O” ring on the main conduit. When the docking cone “O” ring wears, the mid level spray arm conduit is no longer constrained and it can vibrate against the docking cone, making the “growling” or vibrating sound. Use a plastic wire tie to quickly verify if the growling noise is coming from a worn “O” ring. Snug the mid
spray arm coundit against the upper rack with the plastic wire tie. Run the dishwasher. If the noise goes away, you have verified the presence of a worn “O” ring. Remove the wire tie when the test is completed.
The recommended repair for this problem is to replace the WD12X10059 (titanium) or WD12X10121 (grey) docking cone. These parts supercede to the full main conduit. It is not necessary to replace the full main conduit for this problem. Remove the docking cones from both the existing and new main conduits. Install the docking cone removed from the new
main conduit on the existing conduit still installed in the dishwasher.
Posted on Jan 10, 2008
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
Our front load washer vibrates so much durning the spin cycle it actually knocks the dryer off the top of it. It will also vibrate across the floor unless 2 people are holding it down. We have tried the...
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Jul 09, 2009 | General Electric WSSH300G Front Load...
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Maytag MDBTT60AWW rumbling/noisey
most of the noises you are talking about happen often when something is down in the sumpyou need to take the pump apart and you will find something small in there causing the noise! i see if very often and common for this unit.
May 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Noisy spin cycle on washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 11, 2007 | Zanussi FLE1416W Front Load Washer
Rumbling noise
you will find its very possiblely internal gas boiling off in the system.unfortunately you will have to get used to it because if gas is removed to minimise noise,your cooling will become poor. if you put more in, it will get louder and start icing up on the compressor pipe at the back.an exact amount is dialed in on manufacture. this noise ive heard many times.
Apr 09, 2007 | Whirlpool GD5SHAX Side by Side...
GE 24 in. GLD6200L Built-in Dishwasher Logo
574 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
