Question about Sony VPL CS5 Multimedia Projector
Projector turns off
The projector will work for approx. 30 seconds and then it will not project anymore, the fan still runs though.
  • Anonymous Feb 26, 2008
    Did you ever discover a solution to this problem? I have one that is doing the same thing.
  • streetpeople Jan 09, 2009
    vpl cs5 projector power indicator light on. When unit is turned it instantly shuts down. The TEMP/FAN light keeps flasning. Heip!
    street
  • 115 Answers
Pls check the Lamp unit
Viren
Posted on Nov 19, 2007
How to fix wonderwall projector after being unplugged while red light and fan were running
PDF]Download - MS Customer Care
mscustomercare.com/forms/ProjectorIM.pdf
getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
[PDF]Checking Projector Status - Epson
https://files.support.epson.com/Epson.../450W_460lampStatus.pdf
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
Canon Knowledge Center - Turning On and Off the Projector
Jan 18, 2016 | Sharper Image Wonderwall Entertainment...
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Aug 19, 2009 | ViewSonic PJ506D DLP Projector
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
Dell 1100mp data projector
check fan filters.
sounds like you have an airflow problem.
open up and clean out dust.
or fan failure.
check fans are spinning when pj is switched on.
Feb 26, 2008 | Dell 1100MP DLP Projector Multimedia...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Sony VPL CS5 Multimedia Projector Logo
110 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
