Question about Epson Aculaser C1100 Printer
Error 527 paper jammed, but also sounds like ink cartrages do not rotate. When the start up mode is checking printer, it makes a lot of noise then jams the paper.
I have a similar problem, and I solve it. I have been put out manually all cartridges and turn off printer. When I turn it On printer ask to install new cartridges. When I done whit that, problem was solved.
Posted on Sep 03, 2009
  • 556 Answers
Review online guide and trouble shooting for suggestions.
The manuals,online guide and trouble shooting sections could help you resolve your problem. Contact support has a chat facility on some pages that may help.
Click this Link
Under Select a Product Range
Choose Aculaser C1100 on the webpage
Under Select an OS
Choose the operating system1.gif on the machine where you will install the printer on the webpage
Click Confirm Selection
The manuals and documentation link will allow you to download manuals that were on your CD ROM
you may want to bookmark the online guide, if present, to help with future problems -- that probably was not on the CD
Click the back button on the browser
click the Drivers and Software Link
This allows you to download software files that were probably on your installation CD
Click the back button on the browser again
Trouble Shooting and Contact Support could be an interesting link in the future too when and if you have problems.
I hope this helps
Posted on Dec 16, 2007
I have a Workforce WF-2530 printer. When I turn it on, after a few moments it simple says PRINTER ERROR. SEE YOUR DOCUMENTATION." The MENU button does nothing. Holding RESUME and turning printer on
Does your computer have any further information when it's connected? "Printer Error" sounds pretty generic, not a lot of detail to tell you where to look.
I would open the ink loading hatch, and check that there's nothing jammed in there, that all your ink carts are fully seated.
If nothing there, head for the back of the printer, pull the paper-handling tray out, and see if there's paper jammed in there. replace.
Pull out paper tray, make sure there is paper there, and that there's nothing jammed in there too.
When you turn it on, is there any sound, like the printer head moving back and forth?
I have a similar printer, and the error messages I see are rather more informative. . .
Jan 15, 2015 | Epson WorkForce WF-2530
My brother dcp-560cn keeps jamming and making noises as if it is destroying itself have cleared all paper from jam and it still jams why is this
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Problem with Deskjet 895cxi
You may open the rear door to check for any paper jam in side
or if it still gives error rotate the roller in upward direction till you get one locking sound, restart printer and check printing
if you still find grinding noise from printer, its pickup roller gear may be worn-out generally and need to be replaced
contact service person for further repair
Nov 08, 2009 | HP DeskJet 895cxi InkJet Printer
MAKES LOTS OF NOISE BEFORE PRINTING
it is working the ink to the ink cartrage. kinda like cleaning it. it also looks at each side of the paper to know where to print as left to right it leaves a margin on each time. really a good thing.........
good luck
saw
Jul 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Printer suddenly stuck while starting up
eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
May 24, 2009 | Samsung CLP-300N Laser Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
Epson Aculaser C1100 Printer Logo
562 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
