Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Warming Drawer stuck
Unable to open warming drawer due to broiler pan and other things stuck behind the drawer.
  • 473 Answers
Pull the oven out and see if you can get to the pans from behind.  May have to lift up on the back of the oven to get out fallen pans.
Posted on Oct 25, 2007
How do I remove the warming drawer
PDF]Operating and Installation Instructions Warming Drawer
by either removing the fuse, unplugging the unit or manually ... Do not leave thewarming drawer .... Every operating mode has its own temperature range. The.
How To Use the Warming Drawer Feature on Your LG ...
? 1:48
Oct 16, 2012 - Uploaded by ExperienceLG
Welcome To The LG Customer Support Channel! This video will demonstrate how to use the warming drawer ...
Nov 28, 2015 | Kitchen Ranges
Warming drawer not heating
Hi friend, I appreciate your inquiry
Based off the information you have provided it sounds like a possible issue within the element in your warming drawer or the sensor. You may have to schedule a technician to come out and evaluate any damage a spillover may have caused with your drawer. I hope this has been helpful. -Matt
Oct 08, 2014 | Frigidaire Kitchen Ranges
Warming drawer will not open
Good Morning Gloria, thank you for your inquiry!
I understand the warming drawer will not open on your range. The racks or tracks can become bent or misaligned over time and may interfere with the drawer opening or the latch/strike may possibly be broken. If you have checked the tracks and the door strike/latch, and both appear to be in working order, you may want to connect with a qualified servicer to diagnose the exact problem
Dec 17, 2013 | Frigidaire Gallery GLEFZ384GC Kitchen...
How to take apart the drawer to get stuck pans out
Ruler, spatula, bend wire coat hanger, insert between oven bottom and drawer and move back and forth in attempt to dislodge object. Note sometimes objects fall behind the drawer.
Nov 26, 2017 | Maytag PER5510 Performa Electric Kitchen...
A Neff warming drawer red light flashes
There is a 'plug and socket' connector at the back of the warming drawer which does wear and eventually start to make erratic or no electrical contact. The drawer electronics read this as an open drawer and switch off the power to the heating element (flashing red light). If your competent the drawer can be stripped down and the contacts serviced or replaced otherwise consult a service technician.
Dec 07, 2012 | Neff Ovens
Chef premier 091S16FE1 gas cooker. Igniter will not work in grill or oven. Switch tests ok. Need wiring diagram. Would like to know if there is a fuse in the system.
I dont have a diagram but most Chefs have a wiring diagram stuck behind the lower kickpanel or underneath the warming drawer ( if fitted) The Premier was a fairly basic unti when it came out. A lot of these had battery ignition. Look behind the kickpanel or under the warming drawer for a battery box. ( About the size of a matchbox) and has a 9volt radio battery.
I have not seen fuses in these ovens for over 10 years , so I would suggest that yours doesnt have one.
Jul 26, 2011 | Ovens
Unable to close the bottom oven drawer (Kenmore)
Pull the unit away from the wall and in most cases you can reach in the oven pan from then rear. If not.....pull the unit away from the wall and then lift the front about 3 inches away from the floor and let if drop....thus shifting the items in the drawer....If I can help further, I am here
Eric Campion
Feb 23, 2009 | Kitchen Ranges
Stuck warming drawer
sadly there is no way from the top . only thru the door .
Nov 11, 2017 | GE Profile Spectra JGBP85 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,962 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
