Question about Brother MFC 420CN All-In-One InkJet Printer
Receiving faxes my brother mfc-420CN won't receive faxes...I can send just fine, however can't receive
  • Anonymous Mar 25, 2014
    Brother MFC
  • 286 Answers
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Posted on Dec 29, 2007
1. Check OS settings to be certain you are set to receive. I use Mac OSX - print/fax settings have a check box to receive faxes. 2. Open MFC-420CN Control Center.     Open "remote setup".     Expand "MFC" tree to see all options.     Under "fax", choose 'set up receive'.
Be sure you are set to receive and necessary options are chosen.
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
How do i hook up to use fax machine?
put a phone wire from the line jack on the machine to the wall. like this you should be able to send
to receive put the machine in fax only receive mode and only connect the phone wire when you know there is a fax coming in bacause in this mode it will answer every call like a fax
Mar 23, 2010 | Brother MFC 420CN All-In-One InkJet...
How do i use the fax machine
Follow the way.
1. plug on you phone connection with your all in one machime.
2. Then On the all in one machine.
3. Dial no getting tone from other side put your paper in top side copier place.
4. receiving fax make your fax receiving setting automatic. in will came out.
*** But remember before use it you must activate your phone connection for sending & receiving fax. FOr these you have to contact with you phone connection company."
Thanks & waiting for your feedback
Jan 31, 2010 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-8440, send fax ok, but no receiving fax
The manual has step by step instructions, I'll include a link for the online version. Section four runs through setting up recieving, if it's on a dedicated line follow the first set of instructions to set up automated answering. If it's a shared line(phone/fax) then continue down to the next section.
Note: for a shared line you may need to contact your line provider for a second number that has a "dedicated ring"
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf
Hope this helps FixYa,
Chris
Apr 11, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to make and...............
it should not give you any problem if you configure dial up properties of MFC
Apr 02, 2008 | Brother MFC 420CN All-In-One InkJet...
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Fax does not receive or send
plz contact brother hotline of your country ( www.brother.com )because there are so many diffrent telephone standards which might affect a good working of the fax abillity.
Jan 31, 2008 | Brother MFC 420CN All-In-One InkJet...
Printer keeps turning off,,,error message MN1 in lcd
I realise this is an old question but I recently had a similar issue with our MFC-5860CN not receiving faxes and displaying the "Mn1" code. As it turns out "Mn1" means the machine is set to manual receive and was therefore not automatically receiving faxes. You will need to locate the "Receive Mode" option in the menu and change it to "Fax Only" or "Fax / Tel". Unfortunately I dont know what could have caused the turning off and on that the OP mentioned. I'm a little late to the party but I hope this info can help someone else!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
457 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
