Moved into a house with a Ranger 8980E security system that we have done nothing with for 4 years without a problem - don't have any codes or info. Last night the keypanel in our bedroom started chirping sporatically. It's driving us CRAZY! I can't find any battery to replace. The only keypad beeping is the one in our bedroom. WHat can I do to stop it?????
that system is obsolete. the battiery is located in the control panel. most control panels are located in a closet next to the att crawel hole or in the att near the crawl hole. find the panel and if you are not going to use it pull the battiery and disconnect the ac transformer. option 2 find a local company and have them up grade your system.
mj
Was this helpful?
Yes
No
Popular Solutions for GE Security Simon 3 Wireless
I have had a ADT Security system for years however I do not have actual service with ADT for maybe a...
(More)
I have had a ADT Security system for years however I do not have actual service with ADT for maybe a year now but we still set the alarm at night. Recently it started beeking and kept saying low battery. I replaced the battery and it still is not working properly and does not recognize any of the sensors............
My new GE Simon is programmed and ready to go but even though it says doors and windows are armed....
(More)
My new GE Simon is programmed and ready to go but even though it says doors and windows are armed. Nothing happens when I open the doors and windows in armed mode. No sound, no alarm. I know the sound works becuase when I try to access the panel without an access code it trps the alarm. Also, key chain fobs fail after a few hours. They work fine then lose the code. Batteries have been replaced.
have a issue that indicted a low battery replaced the battery have 7.1vdc at the main board when...
(More)
have a issue that indicted a low battery replaced the battery have 7.1vdc at the main board when checking system status still saying low battery,
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it...
(More)
My Optima XM6 fuse blew,I powered the system down,replaced the fuse and battery when I connect it back up the alarm sounds and the code number will not stop it.How do I remedy this?Thanks.
