Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Housing dispenser broken at ice flap
The flap where the ice comes out of is loose.  after taking the front panel off have discovered that there is a part of the plastic housing that is broken off.  So the flap can not be secured.  I have checked with Whirlpool and a local parts company and an appliance repairman.  They all said the part is not avaialalbe and I would have to order the entire freezer door.  The repairman said to try a place where old refrigerators go to see if it can be taken off one.  Is this a common problem.  what can i do?? Please help!!  It is a ED5JHGXRT00 not a ED5VH....
  • SteveCH Sep 07, 2008
    My Kenmore/Whirlpool side-by-side refrigerator (106.55244400) ice despencer flap is broken and stays open causing frost to build up insde the freezer to a point it's hard to open the door. Is there a part/kit to fix this problem? Thans a lot!
  • dmdmoynihan Nov 20, 2008
    I have the same problem with my Whirlpool refrigerator and if you ask me this is a pitiful design. The spring that closes the ice maker door is too strong for the pathetically small plastic hinge assembly that is molded into the icemaker chute assembly. Whirlpool parts customer service informed me that this part is not available and that I would need to replace the entire freezer door ($585.00) with the same pathetically small plastic hinge holding a pin with a spring much too strong for it.
    I just finished repairing my Whirlpool water heater with a part provided free as a result a settlement stemming from a class action lawsuit surrounding the gas temperature probe used to keep the pilot light lit. I now have a gas water heater in my home that keeps me up at night wondering whether the repair I was forced make myself will explode one night while my family is sleeping. What happened to American appliance companies anyway? Have they all sold out and now make junk? The Whirlpool name used to mean quality. Not anymore.
  • 473 Answers
Yes this is a common problem.  However, you don't have to replace the whole door.  They were wrong.  Whirlpool makes a fix kit for this.  You can get it at  The part # is 8201649 and cost is $42.99.  The description will say door chute.  It is a door mechanism assembly.  It is fairly easy to install and comes with instructions.  Hope this helps.
Posted on Oct 25, 2007
  • Robert Riddell
    Robert Riddell Aug 20, 2014
    This option does not work if the tab that holds the replacment part is what is broken. I also ordered this kit, but there was no tab to secure it to the dispenser assembly and the dispenser assembly cannot be serviced or replaced.
    New Friend:
I had the same problem and fixed it with a piece of a picture hanger, super glue, and J-B Weld. Dispenser works perfectly this morning! I don't know how long this fix will last, but if it saves me buying a new freezer door, I will continue to patch the hinge this way.
housing dispenser broken at ice flap - adc8fba4-5f21-4ef1-b362-e45bfffe2eaa.jpg
Here are the steps I used to affix the patch:
1. Cut a small sawtooth hanger (the kind you affix to the back of a picture frame) so that just one "tooth" is left on the end.
2. Lightly scuff the piece of hanger and the plastic nub of the broken hinge.
3. Superglue the hanger piece onto the nub.
4. Apply J-B Weld all around the hanger/nub location.
5. Let the J-B Weld cure overnight before putting the dispenser back together.
Hooked everything back up this morning, and voila! We have have ice and water again! :)
(The jar in picture is because I took this opportunity to bleach the handles.)
Posted on Sep 30, 2013
How do I open the front control panel of my Samsung side by side refrigerator?
I tried to reply on my question, when you asked, I don't think it worked. First of all it sounds like you have a bad control board, or you may have a loose connection. On back of the fridge is your main control board, I think its the first wire at the top to the right, if that wire is disconnected the door will open and close. When I was running some test, I took this wire off and it began to do this. As for taking the display off, simple, took a while to find this out but all you do is take the one screw out, grab the ice shoot and just give it a firm tug, it should pop right out. you have the hose attached and theirs a wire connected so be careful, but that all it takes.
Jun 06, 2015 | Samsung RSG307AARS Stainless Steel Side by...
Kenmore refrigerator model 106.57372700
This is usually not hard to fix. Either the tab that hold the dispenser actuator is broken or the ice guide may have come loose. has a nice video on how to fix this.
Jul 23, 2014 | Kenmore Refrigerators
The despenor flap came off because it had a broken tab. What is the correct way to install a new flap.
you will have to take the dispenser housing out of the freezer door. The black ring or white square ring around the ice and water dispenser comes off. It justs snaps on remove that and you will see the wires and screws to take loose. Once you remove it take the model # and your local supply house will have the part and the directions to reinstall the flap will be inside wish you luck.
Dec 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile 2006 Icemaker (icemaker model: wr30x....) doesn't make ice but cycles perfectly when jumped. Making 8 ice cubes at a time by jumping is cumbersome however. Can you explain how to get the...
The flexible arm is the on off switch to the timer. And the timer is in the ice maker itself. Make sure that arm is in the correct position.
Sep 13, 2010 | Refrigerators
GE Profile Ice flap is broken
The part number you need is WR62X10055 . This is the sokenoid and plunger which operates the flap . They tend to rust badly , keeping the flap from opening/closing . With a small screwdriver , pry the control panel ( from the bottom only ) outwards . This panel is the push buttons for crush , cube , water . Once removed , there are 4 screws , one on each corner of the white housing . Unplug the 3 plugs on the control panel first . Remove the 4 screws and slide out the housing . The solenoid and plunger are at the top right , held on by 3 screws . Replace solenoid AND plunger , and reassemble in reverse . Also , remove the top freezer door hinge cover to access the plug which should be unplugged first . After reassembling dispensor , dont forget to plug the plug back in .
Aug 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flap on ice dispenser does not open
what make and model?-mike
Oct 27, 2008 | Refrigerators
Always crushes ice
This was easy to solve after reading some posts which mention "a plastic flap" which is opened or partially closed by the metal rod running under the ice cube tray.
There is indeed a flap which is inside the front of the removable ice holder/dispenser. The flap should be able to open fully so ice can fall out. In mine it could only move 1/2 inch because the flap was laying on the wrong side of a small peg which guides it.
I was unable to free the flap to open completely by pressing on it, so I had to unscrewed six screws to take off the front plastic facing and the on the front plastic housing. Pushing on the metal rod immediately put the flap back into it's correct position. I then replaced the plastic front.
I can now have either whole cubes or crushed. Boy was that easy to fix!
A repairman recommended replacing the electronics ! !
I assume this misalignment might be caused by too much pressure when the ice cubes freeze solid or something? If it happens again, I know it's easy to fix.
Nov 06, 2006 | Kenmore 55692 / 55694 Side by Side...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
2,144 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
