Question about Maytag MMV5000 Microwave Oven
MMV5000 keypad is intermittent
Seems to work when it decides to. Unit is 8 years old with soft membrane keypad. Sometimes it works correctly every tiem and other times it might take 5 minutes of trying to get the cancel to work and then start over.
  • Anonymous Dec 20, 2007
    Keypad does not work
  • Maytag Master
  • 9,098 Answers
The keypad has failed, and that's usually economical for a do-it-yourselfer.
It would need a new "control assembly switch/mem (wht)" which is otherwise known as the control panel frame assembly with membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
It's reference number 1 on diagram 2, the control panel.
Ironically, the white version runs about $160 but you can save about $55 by ordering the bisque or stainless steel version.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
  • 473 Answers
You have a stuck button on the keypad.  With the cost to replace the part I would replace the microwave.  Would appreciate a solved rating for expert advice.
Posted on Oct 25, 2007
Spacemaker xl1800 ge profile problem
try to reset the settings and also the unit.. if you have an easy access to clean the keypad contact it is better to clean the surface..
Sep 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Unit is 10 years old. Everything is working (keypad, lights, turntable) but unit is not heating food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 06, 2010 | Maytag MMV5000 Microwave Oven
MMV5000ADW Maytag Microwave Keypad stops working. The light switches on and off when the door is operated and works fine. The time display is working. The keypad is non-responsive. Please help figure out...
How old is this unit? have you taken it apart?there was at one time a wiring issue with these units,depends on the age.other wise I'd say you have a bad touchpad it was another common issue with this unit. part number 56001263 in white runs around $80
Sep 27, 2009 | Maytag MMV5000 Microwave Oven
Maytag MMV5000 stopped working
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Apr 04, 2008 | Maytag MMV5000 Microwave Oven
Keypad barely works
Keypad replacement is something most DIYers can handle okay, or for only $39.95 plus parts, we do them for customers nationwide.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Mar 16, 2008 | Maytag MMV5000 Microwave Oven
Microwave not working
Found this Samsung model problem in the Welbilt section but will try to help just the same. Hope you find it.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
You can download your owner's manual here:
http://downloadcenter.samsung.com/content/UM/200303/20030324114252562_DE68_00064C-02.pdf
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
You can order a new keypad (membrane switch) here:
http://www.samsungparts.com/search/search.asp
Please write back with more details if you need further help.
Nov 29, 2007 | Welbilt MR622W Microwave Oven
Intermittent keypad operation
A new keypad is not difficult to install, and can be worthwhile.
It's part # DE34-10139B and you can get one for $18.71 plus shipping from http://www.samsungparts.com
We're able to install them for folks who don't want to do it themselves.
Nov 26, 2007 | Samsung MU3250W Microwave Oven
LG LMVM2055SB over the range microwave keys not working
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Nov 18, 2007 | Microwave Ovens
My microwave computer seems to be possessed
E4 normally indicates a problem with either the keypad or a sensor. Since the oven is resetting, it may be the keypad or even the control circuit board. Below is my info on keypads, which may help, followed by more info: You may also have a bad keypad, which in many cases can be replaced. KEYPAD TROUBLE A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. DISCONNECTING AND CONNECTING THE KEYPAD 1. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the control circuit board. 3. There are two tiny tabs (one on each side) on the hood of the connector that you can gently pull up on to unlock the connector. Use equal and gentle fingertip force when pulling up. 4. The old keypad strip will lift out. 5. Put the new keypad strip in, making sure both sides are down fully. (If you are not installing a new keypad, clean yours with a pencil eraser or a soft cloth and alcohol.) 6. While holding the strip down, push the connector hood back down to lock it. -- If your keypad (membrane switch) is bad, you should be able to get one here: http://www.samsungparts.com/search/search.asp If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you still have questions, please post again.
Aug 08, 2007 | Samsung SMH7178STD Microwave Oven
Maytag MMV5000 Microwave Oven Logo
82 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
