Question about SanDisk Sansa e260 MP3 Player
Sandisk e260 My Sandisk will stay connected to the computer until i try to add tracks. It will download one or two songs before it fails and disconnects from the computer. It also will not let me reformat. Although when the mp3 player is not connected to the computer it runs great. what do you think is happening?
  • 626 Answers
Sounds like some data may be corrupt.
This will wipe it clean and you can start over.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Oct 27, 2007
SOURCE:
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
I want to add MP3's to my e260, won't power on to do so! Help!
Make sure USB mode is MSC....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated....
Download Update if you haven't yet(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) Easier to drag and drop using explorer
Apr 20, 2009 | SanDisk Sansa e260 MP3 Player
E-260 freezes when computer is trying to read it in Rhapsody program
I read some of the other post and found that I needed to use Windows Media Player. I had the Rhapsody program on my computer as well. Once I downloaded Windows Media Player I was able to access the files and add and delete songs.
My husband is not a big fan of Media Player. Lets hope I haven't done anything that he will have to fix. :)
Good Luck.
Aug 10, 2008 | SanDisk Sansa e260 MP3 Player
Sansa 4GB mp3 player
corrupt database
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Deleted everthing!!!!!!!!
Try uploading some songs with windows media player and then delete them through windows media player if it recognizes the tracks
Feb 25, 2008 | SanDisk Sansa e260 MP3 Player
Sensa e260
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Best of Luck.
Sep 05, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Jun 30, 2007 | SanDisk Sansa e260 MP3 Player
Can't view songs on Sansa e260
go into wmp11 and disable the auto synch feature, then you will be able to add your own. depending on the size of the files, and the length of the songs, you are about right with the 510 number.
Jun 27, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
