Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Won't power on , just a click and nothing happens
Won't power on ,  just a click and nothing happens , green light blinks but no others
there is nothing more to describe.
It's 3 yrs  old and 1 year into the second bulb
worked fine and all of a sudden , won't turn on
  • 87 Answers
Re: won't power on , just a click and nothing happens
Bad lamp, color wheel or DMD board. Lamp $199, Color Wheel $350 by professional, DMD/light engine $750 by professional
Posted on Jan 03, 2008
0 characters
3 Points
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Push power button and it clicks once then green light goes out and then clicks again and then nothing happens
Do the self check the model indicated has:
When power light goes out on the front of the set press and hold both the Menu and Input (device) buttons for at least five seconds and then release both buttons.
Watch the power light closely as it will blink a two digit error code: 2 blinks and a pause followed by 2 blinks is the most common one.
It will repeat the code about 5 times and then to get it to do it again you would have to unplug the set and attempt to turn it on again etc.
Let me know what code you find and I will tell you what it means and what kind of trouble you have.
May 01, 2010 | Mitsubishi WT-46805 46" Rear Projection...
I try to turn on the tv and the green light just blinks, nothing happens. After a few minutes it shuts off and the red light blinks two times and pauses. The red light blinks until I disconect from the...
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from
Dec 06, 2009 | Panasonic PT-56LCZ70 56" HDTV
Mitsubishi TV Model VS45609 Blinking Green Light
I have a Mitsubishi VS 45609 tv. I turned it off at midnight and tried to turn it back on the next morning and nothing happens. Can you help?
Nov 03, 2009 | Projection Televisions
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
My 52' RCA does not want to power on. When I click the power button, sometimes nothing happen. But other times the green light blink 3 times then goes off, but the television still does not want to come...
You need a flyback, please respond to this same post with your model number of your RCA and I will post a link where you can get a new replacement with free tech support so you can easially install it yourself.
Aug 17, 2008 | RCA Projection Televisions
New Bulb Doesn't Light
color wheel or light engine,call for service and save your money.
Aug 04, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
