Question about Pioneer PRO-200 60" Rear Projection Television
Cannot program my universal remote
None of the codes listed for pioneer work to program my comcast remote I have the elite pro-119 any suggestions? Thanks
I have a comcast remote that I use on my pro-200. Here are the codes for my remote, hope one of them might work for you. 10166, 10679, 10866.
Posted on Feb 21, 2009
Buy the exact remote from parts
Posted on Apr 12, 2008
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Feb 05, 2014 | Comcast Custom DVR 3 Device Universal...
Need a code for my Sony RM-Y16 Remote to split screen with my Comcast DVR
It is possible that this remote will not program to your Comcast dvr. Your DVR is probably newer than the remote and has new codes that the remote doesn't support. The only thing you can do now, is either purchase a new universal remote that supports both units. or use your Comcast remote to program it to your TV. the Comcast remotes are programmable.
Oct 07, 2012 | Sony RM-Y916 Remote Control
AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
  • Try searching for a code. Some brand names, such as "Akai" may have other manufacturers parts inside of it, Searching usually is done by going through certain key-presses on the remote to try all of the codes available.
  • Buy another Universal remote, not all remotes are created equal as some have mode IR codes built in than others, if you have an odd brand TV, it may be more difficult to come across one that works.
  • Buy a learning universal remote, although usually more expensive these remotes will allow you to "learn" the IR codes from your old remote to the universal remote.
I hope this helps.
Mar 06, 2011 | Akai LCT2721AD 27 in. LCD Television
Pioneer pdp5000ex code for remote
I assume you want the remote code so you can program an universal remote? The "code" for the remote is specific to the vendor of the remote control you purchased not the TV per-se. The directions for the remote control should have a full listing of all brands it supports. usually it has several options for each brand and unfortunately you have to try them all to find out which one best matches the features of your TV.
Sep 21, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Just got a pioneer elite pro 119 from a buddy of
If you don't mind opening the thing, open it up and follow the power lead inside the TV. Somewhere along the line should be a fuse. I'd start there.
Oct 06, 2009 | Pioneer PRO-119 60" Rear Projection...
Code dvd Sharp for RM-101 universal remote
Instructions on how to set up / programme a universal remote:
1) See the code form and find the 3-digit figures for your device.
2) Press "SET" button and hold continuosly, then press the device select button (e.g. TV1, TV2, VCR, SAT, etc. If you are setting up for your TV, choose TV1) you want to control.
3) When the indicator light is on, release the two buttons simultaneusly.
4) Enter the 3-digit figure you have found.
5) When the indicator light goes out, programming is finished.
6) Check whether operation of other buttons is at normal state. If so, your setting is successfully accomplished.
Below is a list of the 3-digit code for a few more popular TV brands that are sold in Singapore. If you have a different device (e.g. VCR/LD/VCD/DVD/etc), and/or of a different brand, please do post your queries here, everyone can contribute and help one another ^0^ Here goes~!
Aiwa: 261
Daewoo: 168, 209
Elite: 108
Goldstar: 003, 004, 043, 080, 153, 172, 252, 700, 701
Hitach: 004, 040, 041, 042, 044, 047, 055, 061, 062, 063, 064, 065, 066, 067, 068, 174, 221, 222, 710
JVC: 077, 119, 178, 179
Matsui: 004, 006, 028, 041, 088, 182
Mitsubishi: 044, 052, 092, 119, 154, 155, 181, 182, 245, 707
NEC: 184
Panasonic: 001, 003, 019, 037, 040, 106, 110, 111, 112, 114, 190, 241
Philips: 003, 026, 027, 046, 073, 113, 115, 155, 191, 192, 193, 194, 223, 266, 230, 242
Pioneer: 000, 027, 067, 243
Samsung: 026, 033, 04, 159, 160, 170, 175, 212, 215, 702, 703, 716
Sanyo: 013, 031, 044, 074, 119, 120, 121, 122, 123, 162, 167, 170, 182, 195, 205
Schneider: 004, 011, 015, 019, 025, 036, 038, 255, 258, 262
Sharp: 044, 054, 119, 124, 196, 198, 225, 227
Siemans: 010, 231, 232, 233, 234, 236
Sony: 028, 119, 126, 127, 128, 129, 130, 182, 199, 228, 260, 705
Tai Wah: 218, 219
Thomson: 065, 067, 075, 078, 098, 100, 103, 185, 186, 222
Toshiba: 022, 044, 094, 119, 138, 139, 141, 142
Aug 05, 2009 | Universal Remote Control Remote Control
Programing a universal ( comcast ) remote to work with AKAI
look in your guide and check the programming procedure for finding an unknown code. it's usually turn the tv on and go into a search mode on the remote and start hiting a button till the tv goes off and then you have just found the code. good luck.
Jan 17, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
I can't get rid of closed captioning!
Closed captioning can come trough 4 sources 3 of them access a digital file and display it to the screen. ALL must be set to off on each device:
Embeded in actual program video source--unlikely your problem.
TV decoder cotrolled by TV menu under "language"
Cable box--ditto for menu selection
DVD player or VHS tuner--Ditto for menu
Sep 17, 2017 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Apr 05, 2008 | Audio Players & Recorders
Pioneer PRO-200 60" Rear Projection Television Logo
212 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
