Question about Sony KV-32S25 32" TV
Sony KV-32S25 32"
No response  no power
  • Anonymous Sep 09, 2008
    It turn off byself after that it won't turn it on
    no power
    what is the problem
  • mknoll10 Jan 01, 2009
    Thanks Terryfic, what else can cause the C4834 transistors and R607 to go? It looks like the Horiz. output transistor is still OK
    Genius:
  • 1,694 Answers
Check Horiz. output transistor = shorted?
1)replace with first quality transistor
2)solder horiz driver circuitry
3)replace shorted converter transistors (2SC4834)
4)Replace open R607 .1 ohm 1/2 w.fusible (resistor ok)
   test.......T.
Posted on Oct 26, 2007
SOURCE:
Sony sony kv-25v25 no power
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 14, 2014 | Sony KV-27V55 27" TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Standby light blinks you hear the contactor clicking in set, no audio and no video displayed. sony kv-36Hs500 only looking for response if this is free of charge
this symptom is usually caused by a breakdown in power supply circuit or it may also be caused by a breakdown in the horizontal deflection circuits which includes horizontal oscillator, pre drive or drive circuits, horizontal output transformer, horizontal output transistor and high voltage circuits (flyback transformer). pls observe precautions in dealing with this high voltage circuits and if so happen you are not inclined with this kind of work, it is better for you to bring it to a qualified technician to avoid accident. good luck!
Jul 27, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Can the sony 36" flat wega tv model KV-36FS17 still get a picture useing rabbit ears after february 19th.
No you will need a digital converter box for this TV as of Feb 19th
Please rate my response and keep this site FREE!
Thank You!
Jan 06, 2009 | Sony KV-36FS17 36" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Power Problem AGAIN!! KV-32FS120
Wish I could reach the set from here; I'm pretty sure the problem is caused by a 50 cent (maximum!) part called a capacitor in the range of 4.7 - 100 uFd that is responsible for feed back that keeps the power supply ticking. If you decide to have it repaired and the problem is as above, tell the tech to use a low ESR part and add a .1-.5 uFd ceramic capacitor in parallel to the one he/she replaces. That cap will handle the fast rise times that causes the electrolytic cap to break down chemically and fail.
Oct 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-27V42 27 - 4 blinks
horizontal output transistor (HOT) check IC1751 for short between pin 4 and 6
Apr 02, 2008 | Sony KV-27V42 27" TV
Sony 36inch trinitron, power light blinks four times
Good day.
try to resolder the circuitry and also check the status of the horizontal output transistor. Check for the output voltages 130v, 12v and 9v.
Any of 3 reference voltage missing will disable your units function.
Response is highly appreciated.
chris
Mar 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Mar 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
205 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
