Question about Samsung LN-R409D 40 in. LCD Television
Samsung lcd tv le32r8 (Picture - Movie setting)
I have a problem where i set the picture to Movie quality and after about 10 minutes it flicks back to Dynamic. How can I stop this happening?
  • 1 more comment
  • Orsky Dec 30, 2007
    Hi, my brother-in-law called me today with exactly the same problem. He's calling Samsung tech support tomorrow who will hopefully shed some light on it. At least he's not alone so its likely to be a software bug or something.
    Cheers
    Tony
  • belaerno Mar 25, 2008
    I adjusted a wide zoom picture but after a while (app. 20 minutes) the picture came back to auto mode. The TV does always this.
    If I modified one of the default parameter the TV went back to the default value after app. 20 minutes. The LCD TV type is LE32R8.
  • Grumpygoat Jun 09, 2008
    Same sort of problem with the Samsung LE32R8 - whatever picture setting is selected some time later it resets and the picture changes - normally to "letter box" it is really, really irritating!!!
The TV is probably in Shop mode, when your TV is initially turned on you can choose between Shop mode or Home Mode.
In Shop mode the TV automaticly returns to the standard setting after a while, they do this so customers can "play" with it.
Press down de Volume button and then hold down the Menu button for five seconds on the side panel of the tv.
Posted on Jun 12, 2008
I also have this problem , and Im sure that my TV is not is Shop mode. My Tv is LE32B650. Wide-zoom is changing to default every time i change program. Zoom is back to default every time I visit HD program (channel), and back to normal SD program.
Posted on Jan 12, 2010
New Samsung LN40A550 LCD TV: picture is not crisp.
If you play with blu-Ray with HDMI, you will see the amazing picture quality.
I guaranty.
Jan 27, 2009 | Samsung LN40A550 LCD TV
Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
May 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung LE46F8 picture setting
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you save any picture settings such as brightness or contrast.
To get the TV out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with “Dynamic Mode” shown on the screen. At this point the picture parameters can be changed and saved.
Feb 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Dec 28, 2007 | Samsung LN-R409D 40 in. LCD Television
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Nov 13, 2007 | Samsung LN-T4061F 40 in. LCD HDTV
perchè quando collego il computer al televisore l' audio è assente?
Oct 15, 2007 | Samsung LN-R409D 40 in. LCD Television
E-mail images
What is the Macro function used for? The Macro function allows you to take close-up pictures. Use the Macro mode when you are 8.4” to 19.2” away from your subject. Where is the Reference Manual for the D-390? The Reference Manual is located on the Camedia Master CD-ROM and is available in four languages (English, French, Spanish, and German. The manual can be viewed on your computer screen or printed on your printer. How can I get traditional photo prints from my digital camera? Most photo processing centers or digital printing Kiosks can make traditional photo prints from a digital camera. There are also many on-line photo processors which conveniently deliver prints by mail. You can also make prints yourself if you have a photo quality printer like the Olympus P-400 printer. Why are there so many quality settings? Different quality settings are used for different purposes; for example, lower quality settings can be used to e-mail pictures because of its small file size. Higher quality settings are used for printing photo quality images. What settings should I use to get the best picture quality? The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K. What is the video output used for? The video output is used for viewing images from your camera to a TV. A slideshow can be accomplished by using the camera hooked to the TV or recorded from a VCR. When taking macro images, can I use the viewfinder? Since the viewfinder sees the subject different than the picture taking lens, we recommend using the LCD monitor screen for taking macro pictures. The image previewed on the LCD monitor will be the exact image that is taken. How do I make a Panorama picture? You can easily make panorama pictures with your D-390 by “stitching” together multiple pictures. First, activate the panorama mode on the camera by selecting Mode Menu - Camera - Panorama. Take your pictures while making sure to overlap the edges of the images. Download your pictures to a computer and then use the “Panorama” function in Camedia Master to stitch them together. For more detailed information, please refer to the camera documentation. What is movie mode function? The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode. Can I add sound to a movie made with my D-390? The D-390 does not record sound in the movie mode. What is the best way to e-mail images? E-mailing pictures that were taken with your camera is as easy as attaching a file to your message.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Samsung LN-R409D 40 in. LCD Television Logo
1,089 people viewed this question
Jerry Greenberg
Jerry Greenberg
