Question about Refrigerators
SubZero 532 Ice Maker Makes One Large Block of Ice
My Subzero 532 Ice Maker seems to make ice just fine but the ice drawer is accumulating excess water which subsequently freezes all the crescent shaped ice together into one large unuseable block of ice. This seems to be a reoccuring problem (every 1.5 to 2 years).How can I fix it myself?
  • 146 Answers
SOURCE: subzero model 532
The trick to putting the drawer back correctly is to ensure that the auger pushes into the motor coupling. To achieve this you will have to put the drawer in place and gently push it in while turning the auger inside the drawer by hand. You will know when it has clicked in.
Posted on Nov 04, 2007
SOURCE: subzero 532 ice buildup in frig
Not enough refrigerant in sealed system or/and restriction in capillary tube.
HTML clipboard
Sub-Zero Service Experts in LA Metro
Posted on Aug 19, 2008
  • 56 Answers
SOURCE: SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Posted on Dec 03, 2008
  • 59 Answers
SOURCE: 532 ice maker works, but dumps water into ice container with ice.
Do you still have a manual or can tell me the watts power consumption of the 532?
I'll look into your question. Sounds like a sticking icemaker water valve, but I'll have a look.
Posted on Mar 06, 2009
  • 1524 Answers
SOURCE: The ice maker on my subzero 650 makes ice. But
The water valve is not seating properly due to particles of some kind. Valve is located on the bottom.
Posted on Jun 07, 2009
SOURCE: Subzero 642 Ice maker issue
Called repair service that seller recommends.
Posted on Aug 22, 2009
0 characters
1 Points
My model 650 subzero ice maker won't make ice after cleaning out freezer drawer
make sure your ice tray in in the righ position. really important. the tray have to press the ice maker switch. or bad ice maker or bad water valve. also make sure to press the ice maker key. in the display. ONLY IN NEW MODELS
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
I have a subzero model 532. I turned off my
its quite possible that your fill tube is clogged with a bit a ice
Oct 09, 2009 | Refrigerators
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Aug 22, 2009 | Sub-Zero 642
Large ice block is forming behind the fruit drawer.
i assume you have a model 650 or 550. Your drain line has clogged then frozen. You need to defrost the ice then clear the drain line. I usually knock a majority of ice away then defrost the rest. Once you have defrosted the line you need to clear it. I use high pressure nitrogen to blow them out, but a turkey baster will do just fine. Fill the turkey baster with water, disconnect the drain line from the drain trough. While holding the baster into the drain line squeeze the bulb to force the water into the line. It may take a couple of tries. Reconnect the drain to the drain trough and you should be all set. If you let this go too long the insulation may be saturated and you will have to have a tech install a drain tube heater kit. If you have questions call the factory at 800-222-7820 or go online to the locator page:
Feb 21, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Ice maker making ice with black specs in the cubes
youlkl need to replace the ice amker assy, the finish on the mould assy is coming off. only solution is repalce the entiire ice amker asssy
Nov 06, 2008 | Refrigerators
Subzero model 532
Fernando is right! Now I will put it in girl terms. The lip of the drawer (lip is at back of the drawer) rests on a white plastic thing. But when you take the drawer out completely, the white plastic thing retracts and just looks like the back of the fridge. So when you go to put the drawer back in, you see nothing to put the lip on. So pull the white plastic thing (it looks like a white plastic rectangle about the size of an envelope) forward and then hook the lip onto it and gently pull the white "augur" (the thing that senses when it's time to make ice) down and slide the drawer back in. My son figured this out from reading Fernando's solution. What a relief! Our model is a 561.
Nov 03, 2007 | Sub-Zero 632 / S
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
