Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
F06 error I have a HE3 42822 washer. It suddenly is giving the F06 error then stopping. Right before it does it there is a really loud buzzing, like grinding gears, metal on metal, or something similar. Any thoughts on what that would be and how to resolve it?
  • Anonymous Mar 28, 2008
    Hi! I have a Kenmore ELITE washer and I started getting the F03 code as soon as starts rinsing and than it stops and I start getting a beeping sound and the F03 code starts flashing. Not to sure what's the problem!
    Scholar:
  • 146 Answers
Check the drain pump. There may be something jammed it it, causing it to overload, and bringing up the fault code.
Posted on Nov 03, 2007
SOURCE:
I have a whirlpool wfs1276aw. It suddenly stopped working displaying the error F06.
pl.check the current and voltage with the meter and continuity test after unplugging the mains chord,which may give some iferrence
Dec 02, 2014 | Whirlpool Washing Machines
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Oct 21, 2013 | Maytag Washing Machines
Whirlpool quiet partner 1 is suddenly loud
Dear Sir : please see the diagram attached.
May 08, 2012 | Whirlpool Dishwashers
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
Washer suddenly stopped agitating and emitted a loud buzzing/grinding noise.Was able to get the water to drain but it won't do anything else except make the noise. I should probably mention that I had a...
A heavy load like a comforter and rugs should never be done in this type washer because it breaks the drive coupling. themobilian_537.jpgthemobilian_538.jpg
The good news is it is really easy to fix. I have a couple of videos here:
themobilian_539.jpgthemobilian_540.jpgthemobilian_541.jpgthemobilian_542.jpgthemobilian_543.jpgthemobilian_544.jpgthemobilian_545.jpgthemobilian_8.gif I have a manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 25, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore Elite HE3t Giving a code F 06
"F06" is a Motor Speed error code. This is an indication that there is a problem with the Drive Motor, Tachometer, Motor Control Unit (MCU), Central Control Unit (CCU) and/or interconnecting wiring between the all these components. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by checking all the connector plugs between the CCU, MCU and Drive Motor to ensure none of them are loose or have corroded contacts.
Read through the link and follow the steps provided. If you have questions, please let me know. I hope this helps.
NOTE: The majority of the time this failure is attributed to a bad tachometer which is located on the MCU. If defective, the MCU must be replaced. There is a technical data sheet that comes with the washer. It is located inside the washer behind the lower toe panel directly below the door. The panel comes off by removing the screws located under bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. If the tech sheet is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. Included are all the diagnostics and troubleshooting advice for your washer, including diagrams to show test points. HINT: For better access to the screws you can prop the two front feet of the washer up using a 2 x 4.
Sep 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite is giving me F06 error. Any
"F06" is a Motor Speed Error. The following link explains:
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
200 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
