Question about Garmin GPSMAP 525s GPS Receiver
Garmin 525s will not turn on
I connected the unit to the battery, the unit turned on for 1 second and then turned black.
After the first try nothing happens when I try to turn it on.
The unit was connected red wire to plus and black wire to ground.
  • Rolf1 Oct 25, 2007
    I noticed on Garmins support page that a unit upgrade may fix the problem:
    Changes made from version 2.40 to 2.50:
    • Fixed a problem that could cause the unit to shut down shortly after power-on.
    I live in Norway and bought the GPS from USA.
    It would be nice to fix the problem at home instead of sending it back.
    Is it not possible to reset the unit ? Maybe some magic button combination?
I tried to reset it but it did not work. I have shipped the GPS back for a replace.
Thanks for trying to help. When I get the new GPS I will start with updating the software as described.
Posted on Oct 29, 2007
    Novelist:
  • 113 Answers
This is a common problem with 400 and 500 series garmins.  The only fix is to take it back and exchange it.  There has been a software update to prevent it from happening but once it powers down it's too late for the update.  This has been a known problem since they hit the market in May. Any respectable retailer should exchange it with no questions asked, especially if you just bought it.
Posted on Oct 25, 2007
  • Paul Hyde
    Paul Hyde Oct 26, 2007
    In order to do the update, the unit needs to be on.  To do a master reset hold down the home key while powering up the unit.
    I tried this with a 440s with the same problem and it would not power up, but you may have better succes with this model.
    To do the update you nneed an sd card reader.  Get a blank sd card and  format it.  Power up the unit with the blank card in the slot.  This will prep it for the download. Now go to the garmin website, select "on the water" then select "chartplotter" or "sounders".  Find your model on the list and select it (make sure it's the 545s, not just the 545!).  When you go to the web page for your model there is a box with a link to update software (usually in the upper left side of the page).  Download the update to your PC, then run the program with your blank card in the card reader.  After the program transfers to the card, turn on your 545s and insert the card. A system info screen pops up.  Select "update software" and the update should begin automatically.  When the update screen pops up you may see an ambiguous message that says it doesn't recogn ise the card.  Ignore that and try the update anyway.  When the update is done the unit should show the new software versions, with the old ones in parenthesis.  It may also restart.
    If this doesn't work, there is a Garmin service center in Europe, but I'm not sure where.
My garmin nuvi 2595 lmt will not turn on, recharge, nothing but a black screen. I pressed what i think was the reset button several times but nothing. Once I heard a sound as if it was going to turn on...
Take a look at rear USB port. Insert the plug. Gently wiggle the plug. Does the USB port appear loose? A common problem with this model is that there is little mechanical support for the USB connector. If it breaks off of the printed circuit board, there battery will nit be able to be charged and the unit will appear dead. Have you tried holding down the power switch for at least 10 seconds?
Aug 14, 2013 | Garmin nuvi 200W GPS Receiver
My Garmin Nuvi 760 screen goes black after 8-9 seconds. I have replaced the fuse in the charge cord. Someone recommended that I remove the battery and turn the power button on for ten seconds to reset the...
Do not open the nuvi, the garmin site recommends the following method instead:
  1. Make sure you are sliding the power button all the way to the left.
    • If the unit does not respond, it may be that the battery is not charged.
  2. Connect the nuvi to a power source such as the USB cable and your computer.
  3. Reset the device, if the problem persists, by sliding the power button to the left and holding it in that position for 10 seconds
    • This resets the unit and prompts it to power on
If this fails to solve the problem, contact "SUPPORT" at www.garmin.com.
Please rate this reply if helpful - good luck.
Jun 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
My New Garmin Nuvi 1400 will not turn on - it just gets to the screen "Loading maps" and then the screen goes black. I have tried the suggested holding down the power button for 10 seconds, but nothing...
My Garmin Nuvi 1490 was on for five or six hours driving then the screen went dark and now unit will not turn on or light up screen at all ? ANY HELP OUT THERE ?
Feb 09, 2010 | Garmin nuvi 1490T GPS Receiver
Nuvi 255w Turns off (screen goes to black) after a few seconds to a few minutes. No consistency on amount of time. "Turn Off" may be incorrect - screen goes blank/black Sometimes i can immediately turn it...
I have a Garmin 255 myself. And what I have found is, MOST of the time, the problem is that the CHARGER CABLE has an intermittent connection in it! So, when the cable moves, flexes, or stretches, the battery charge STOPS, and the (mostly discharged) battery cannot support the load, so the unit blacks out and turns off. Try S-L-O-W-L-Y moving the cable while connected with the unit on, and watch for evidence of a bad cable! Sometimes a DIRTY (trapezoid- shaped) connector will do the same thing!
May 11, 2017 | Garmin nuvi 255W GPS Receiver
Garmin 305 will not turn on, charge, nothing
try holding down the reset and mode buttons together for 10 seconds, then try turning it back on.
Sep 19, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin nuvi 260 won't turn on
There is a reset button on the bottom of the unit. Push it in with the tip of a pen. Worked for me!
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
My 755t says it was getting a update of some kind software update then it couldn not find sats while it was turned on in car then it wentt black and wont start up again. tried usb nothing??? help just got...
happened to me too bro... I posted this:
Garmin 755T BLACKOUT 2009!!!! Solve Basically, me and my wife had to pick up a friend 2 towns over. I jump into my car and input... (More) Basically, me and my wife had to pick up a friend 2 towns over. I jump into my car and input directions to her friends house. All of a sudden my GPS 755T is telling me that it is trying to update the firmware. I press ok. it displayed 1% said done and it couldn't find the Satellites. I was like WTH and turned it off and back on. It stated Cannot find Satellites. I was like ok, let me keep it on the charger 12V Cigarrette lighter. I thought it would start working while we drive and my wife was trying to turn it on but the screen went black and now I'm pissed because I just brought this thing. I went to Garmin's web page but there was nothing informative. I guessing something happened when this Firmware was trying to download into my unit. It must have killed something. It is now 10:27pm June 24th and I'm just surfing the net looking for similar experiences. now I know I'm not the only one. GARMIN WHAT HAPPENED????
Jun 23, 2009 | Garmin GPS
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Charged my new nuvi 760. Unit will not turn on. Followed the steps in manual, held the on button to the left for 8 seconds, then turned it on and nothing. If I plug it back into the wall charger the Garmin...
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Apr 28, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin GPSMAP 525s GPS Receiver Logo
1,019 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
