Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Nec px 42vp5
By ralphazbill on Oct 25, 2007
Powers up momentairly then back off.
It appears to be on the center board or at least that is
where the power goes in and a small 12v relay kicks in then
a few seconds later off. Once in a while it tries a couple of times.
I believe the center board to be the power supply. It carries the
sanken electric co label with pnt-426 on it. I can not find a repair
manual nor have I been able to find where I can find replacement parts.
Any help would be appreciated. The only steps I have taken is opening
the back and visual inspection which rendered no visual evidence that it
is this board the only indication is that is as described above where the
120 v power enters and where the 12 v relay is that is actuating and that
is audible.
Ralph Azbill
A-Z Tech
Ralph_azbill42@yahoo.com
Same Problem
Nov 03, 2008
-   I have 8 nec px 42vp4g 1 of which is working. All of the other 7 have the same symptoms as have been described. I first suspected the power supplyPNT-426. and took it from the working set and passed it through the remaining 7 with no success they all stayed the same. I also took the 7 suspect psu's and put them in the working set voila they all worked.
Somebody must have the answer, It is not the PSU. I will go through every panel until i find it. but in the meantime you could save me and everyone else alot of time by posting it here.-   Guest
Aug 17, 2008
-   Same issue on 42" Plasma, amber light to green light to amber with audible click -   jon7823
May 11, 2008
-   Yes the same problem I am fancing in PX-42VP4G that Moniter is become
on standby after few seconds using PNT-428 Power Supply-   Guest
Best Solution
posted on Mar 10, 2009
Very Helpful)
shees
Rank: Apprentice
Rating: 100%, 2 votes
The fault is on the PSU board.
Replace D 28 on the PSU board. You have to use a fast diode (I used BYW 95). Replace also the
330 uF/35V and the 22uF/50V near to this diode.
After this the unit will work perfect.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
im looking for a Dynex 62" 720 HDMI HDTV PANEL..PLEASE HELP
Answer
Answer
try to turn on tv and it makes a clicking noise and eventually it turns on but seconds later it... (More)
Answer
have a problem with my 42'' lcd philips tv. after being on for awhile the picture has speckles and... (More)
Answer
my samsungle40a656a1f tv will not always power up
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
