Question about Nikon D200 Digital Camera with 18-200mm Lens
Vivitar 636 and Nikon D200
Hello:
I cant seem to get the Vivatar 636 to sync with the Nikon D200 in ATTL Mode is there a trick to this?
    Scholar:
  • 97 Answers
You won't be able to use older TTL flashguns with the D200. Since the D70, all nikon cameras have used "iTTL", and earlier DSLRs (eg D100) have used "D-TTL". Neither of these are compatible with the older TTL system used on film cameras. The newer SB-400/600/800 flashguns are all ok, and Sigma and Metz both produce iTTL compatible flashguns. The new flashguns will work on old cameras but not vice versa.
I know this is annoying, but there were good technical reasons why Nikon changed the TTL standards.
If the 636 has an A mode (non TTL) this should work ok, otherwise it will only work in manual (if it has a manual mode).
Posted on Nov 19, 2007
Running in TTL mode with Nikon D200, flash EF-500 DG ST NAd, doesn't work. In manual mode everything runs well.
this flash is not compatible with the d200. i had one and sent it back to sigma, they upgraded the software in the flash for free. now it works in all modes, it needs to be iTTL to work on the nikon d200 the NAd version is not iTTL.
Jan 01, 2011 | Sigma EF-500 DG ST for Nikon Flash
Old vivitar lens to adapt to a new digital camera
The nikon d80 you pointed out is a solid good camera. Id suggest buying it, if you are sure your lenses fit, didnt bother to check But I know Nikon is the way to go!
Mar 28, 2008 | Cameras
Is the Vivitar Series 1 compatible with the D200 Nikon Digital SLR camera?
Yes. Bear in mind that due to the sensor of the D200 being smaller than a frame of 35mm film, the crop factor will make this lens seem like a 150-600mm.
Nov 17, 2010 | Vivitar 100-400mm f/4.5-6.7 Series Lens
Sb800 firing without pressing shutter release
sounds like a short in one of the circuit boards, most likely one or seveal of the ribbons and boards will need to be replaced to correct the problem. Send in for repair expect to pay up to $200 for a Nikon factory overhaul
Feb 21, 2010 | Nikon Speedlight SB-800 TTL Flash
Vivatar 870hd camcorder
i cant turn on the light flash on the vivitar ddvr 870 hd
Feb 17, 2010 | Vivitar DVR-550 DV Camcorder
Nikon D200 S, CL, CH spindle has slipped....
Take it to a Nikon authorized service centre. Don't try and fix it yourself.
nikon authorized service centre Google Search
Oct 27, 2017 | Nikon D200 Body Only Digital Camera
I want to know how to use the 952AF/Nik with the nikon d200 using multi flash units with the commander mode set to channel 1
The vivtar 952AF flash is not compatible with the D200 in commander mode. Only the Nikon SB600, SB-800, SB-900 will work with that camera wirelessly.
Oct 11, 2009 | Cameras
Where can I get 10pin terminal and flash sync terminal covers for a Nikon D200
you get your things from here click the below link
http://cgi.ebay.com/Nikon-Flash-Sync-+-10-pin-caps-for-D200%2FD2Xs%2FD2X%2FD2H%2FD1_W0QQitemZ250501628194QQcmdZViewItemQQimsxZ20090921?IMSfp=TL090921165005r23188
Sep 22, 2009 | Nikon D200 Body Only Digital Camera
Vivatar Tripod V3000 Camera Attachment Adapter for Nikon D80
Try www.tripodquickrelease.com They have that exact model listed and the plate sells for $16.99
Jan 09, 2009 | Vivitar V-2200GX Tripod
D200 compatibility ?
Metz says yes: Metz
Certainly Nikon will say no. I would double check the fit of the shoe on the camera. The pins on the flash should be springy to the touch.
Feb 13, 2008 | Metz 44 AF-4N TTL Flash
Nikon D200 Digital Camera with 18-200mm Lens Logo
334 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
