Question about RCA RTD170 System
The player wont open tray.
The player wont open the tray, it says "THE PLAYER IS LOCKED", but when I check it in the parental control , it is unlocked. How do I open dvd tray? thanks in advance. Glen
  • Anonymous Mar 03, 2008
    lock on no open
  • janthe May 11, 2010
    I need to open my dvd player it is saying dealer lock is on
Take and hold down the stop button on the remote, and the tray will open.Just hold it?
Walter
Posted on Feb 07, 2008
SOURCE:
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
Mar 24, 2011 | Toshiba SD-K740 DVD Player
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
Every time i try to put in a disk, it says its locked
Yes,Some one have set the child lock ON accidently.so it appears as LOCKED
As this child lock is ON you cannot open the tray.
Please follow the below steps to open child lock,
When player is in standby mode press RETURN,ENTER and then ON/STANBY BUTTON again.
You can open it.
If it appears as TRAY LOCKED ,You should contact your sony dealer or authiorised sony service centre.
Thanx
Jul 26, 2010 | Sony DVP-NS315 DVD Player
SOny DVD Player DVP-NS50P Locked
press stand by and press return button and enter button and then press stand by button on ur remote control.the player will be unlocked
Dec 27, 2009 | Sony DVP-NS50P DVD Player
Locked dvd tray.
Press Setup then the numbers 2 0 0 5 then setup and it should unlock
or
Display 2 0 0 5 Display
Dec 22, 2008 | Toshiba SD-K760 DVD Player
DVD player parent lock
My unlock code is 0123, I didn't set it but it works to unlock parental controls
Mar 28, 2008 | Disney Televison & Video
SONY DVP NS5OP is LOCKED
probably you locked it mistakenly, what you should do leave the player in standby, press RETURN, ENTER and then POWER buttom again. watch a nice movies.
Feb 07, 2008 | Sony DVP-NS50P DVD Player
Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Nov 12, 2007 | Sanyo DVD-7201 DVD Player
Rca rtd170 "player is locked"
no thanks to the solutions listed-i have figured it out! you use the remote that it came with and press and hold the stop button on the remote and the dvd player at the same time and it will open....waalaa.....i'm a friggin' magician man...hahahahhahahaa
Oct 12, 2007 | RCA RTD170 System
Won't eject disc
had the same prob with a sony dav dz it kept saying locked but after hours and hours of pressing random combinations it came off im sure it was unplug plugback in then hold power and open tray and tap stop or a combination of those buttons.i woud try it again on mine to make sure but i do not want to lock it again.
Mar 03, 2007 | RCA RTD170 System
RCA RTD170 System Logo
336 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
