FixYa.com
Tags:
NEC SuperScript 870 Laser Printer
Need Help with NEC SuperScript 870 Laser Printer (by 2 users)
By Lizzy - usenet poster
My NEC SuperScript 870 Printer has developed a small problem with an
image dropout along the left side of the printed page.  It is slight
but noticeable.
It is not a sign of low toner, as the toner cartridge was recently
replaced. Before I have to spend the money on a new photoconductor
cartridge, I'd like to try cleaning or other diagnosis of the problem.
Are there any experts here?
Other than pulling out the toner cartridge and photoconductor
cartridge, what else can I do to examine and/or clean the unit?  Do
those printer cleaning sheets made by Kensington do any good?
Many thanks for any help you're able to offer.
 - Earl
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Jonbrath, posted on Jun 09, 2008
In my case, the printout always displays a smudge line down the right side of the page at the margin.
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Joey2
Joey2 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I apologize if these seem obvious.
Have you made sure the toner is distributed properly within the
cartridge by rocking it back and forth?
If you se an exposed corona wires, or if the cartridge has internal ones
which are accessible via a trap door and there is a tool provided, use
it to make sure these are not coated in toner.
If you see a window that the laser "shoots" through within the printer,
make sure it is clean.
Art
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
In message <1121695211.623130.234 @z14g2000cwz.googlegroups.com>­,
earlsjo @gmail.com writes
Is it a two part printer? Does it have toner and developer?
Other things that might want cleaning: Does it have a laser lens cover
that can be removed and cleaned?  Are there wires (the phrase corona
wires sounds right) that can be cleaned, maybe by the machine itself?
Does it have a menu which covers some cleaning options?
Timothy
Solution #3
Not Rated (0)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
Timothy -
The two replaceable parts are the toner cartridge and the photoconductor
cartridge (the "drum").  I had a TI Microlaser many years ago that had a
replaceable developer cartridge also, but this printer is not like that.
What I would like is some specific advice on cleaning, and what to look for.
Thanks.
Can you Help with these Printers problems?
Printers
How do I get rid
How do I get rid of red-eye on... Answer This...
grinding sound from priter...
sometimes the paper jams and... Answer This...
Lines, characters, pages...
My NEC 870 has suddenly started... Answer This...
NEc 870
I have an NEC 870 that I have... Answer This...
no response, all lights on...
all the panel lights are on, I... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
