Printing,hp deskjet3420 hi,my name is malcom,i'm using win98, when trying to print i get, error writing to lpt1
Windows not recocniz deskjet3420
Posted on May 29, 2008
    Brigadier General:
  • 6,966 Answers
Hi Malcom,
The HP3420 is connected to your PC through the USB port and not through the LPT1/parallel port.
You have to change the port setting. Go to Start, Printers, right click on HP3420, click on Properties, go to the Ports tab, check/select USB, OK.
Alternately, you may have to re-install the drivers for the HP3420 and allow the program to Search for the printer connection. Clicking on the button Stop Searching will auto install it again to LPT1.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Oct 26, 2007
Hi , We're trying to print the file to TLP 2844 using DOS commend : copy test.txt LPT1 , but the printer does not response . We installed the out-box driver and make the driver pointed to LPT1, It...
the only thing I see missing is the ":" after lpt1
ie - command should be copy test.txt lpt1:
you could also try using print test.txt
or type test.txt > lpt1:
Mar 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Cannot print from outlook express
u did not write which operating system u r using
>>if u go to the printer icon
>>u will find there is tab called "add a printer"
>>click on that >click on add a local printer >select the port for xp it would be usb virtual 001 port >or it is netwok connection select "lpt1">next page left side select hp as a manufacturer>and in the right select 990c>and next>select the printer as your default printer >now try to print from outlook
Dec 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Foxpro dos programme not printingin usb printer laserjet cp1515
You can access your printer connected to USB port with loop back configuration and print from DOS.
Not only that, you can also print to a printer on the network
Try
Net use lpt1: \\Comp name\ printer name /persisten:yes
Dec 31, 2008 | HP PSC 1610 All-In-One InkJet Printer
Print not comming
my printer hp 2300 print only on page
Sep 17, 2008 | HP LaserJet 2300 Printer
Error problem
I found this problem raised because of improper installation of drivers. I have down loaded the drivers from HP site and got it rectified.
Aug 29, 2008 | HP DeskJet 3745 Printer
Printer not printing from computer
Hello:
To resolve this situation try the following:
1) re-install a driver. Goto HP.com and download a anew driver. COmpletly uninstall the old one.
2) Force your deskjet to run a self test...disconnect the cable from the PC...power off the unit...hold down the print button...turn unit back on.
3) try a new cable
4) Download a manual here
I hope you are up and printing soon.
Good luck to you my friend,
Seek PC Repair
Feb 10, 2008 | Compaq Presario 5000 PC Desktop
Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
HP DeskJet 5550 InkJet Printer
Well, first things first! Are you using the parallel port (the "wide connector" one) to connect or the USB(The small connector)? Get back to me with this info to continue troubleshooting! regards, babb
May 04, 2007 | HP DeskJet 5550 InkJet Printer
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
