Question about Logitech 967437-0403 Keyboard
My keyboard is inserting spaces where they don't belong.  it is usually around R's, N's and spaces (I  press the   spacebar once it it inserts 2 or three spaces, the  faster I type the   worse it gets.) here is an example, see the   above ... there I  only pressed the spacebar once. also qwe r qwe r qwe r qwe r qwe r qwe r qwe r (I never pressed the spacebar) HELP
  • Gracia_2 Mar 17, 2008
    I have the same problem. i.e. th e s am e pr obl em . It is a Lenovo 3000 N200 using Windows Vista Premiun and Microsoft Office Suite.
  • 151 Answers
You should open the key board.and clean space key and change rubber cap.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Mar 14, 2008
Spacebar disfunctional
change out the keyboard or turn machine upside down and shake it gently. You may have something stuck under it
Apr 27, 2014 | Microsoft Windows 7 Professional Upgrade...
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
You may have some small item underneath the spacebar. The spacebar will "pop up" if you use a screwdriver or something to pry it up from the keyboard. Insert it near the B on the top side of the spacebar and pry up towards you. Clean out from underneath and reattach it.
Apr 16, 2011 | HP D8597A Keyboard
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
The insert key does not allow me to type over an existing sentence. Does HP have this functionality?
I was having the same problem on a new HP keyboard. I found a solution for my issue in the WORD 2010 help menu:
"To change the overtype settings so that you can access overtype mode by pressing INSERT, do the following:
  1. Press ALT+F, T to open Word Options.
  2. Press A to select ADVANCED, and then press TAB.
  3. Press ALT+O to move to the Use the Insert key to control overtype mode check box.
  4. Press SPACEBAR to select the check box, and then press ENTER.
To turn Overtype mode on or off, press INSERT."
Aug 26, 2010 | HP D8597A Keyboard
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
Can't/use/my/spacebar/ don/'t/have/recovery/cds/for/satellite/135/using/vista
I'm afraid that your recovery CD's won't help you get the space bar working.
There could well be dust, biscuit crumbs, hairs etc that's preventing the spacebar from working, turn the laptop off but don't close the lid, stand the laptop on it's side and get yourself a clean, dry paintbrush.
Start to brush the keys and gently tap the keyboard with the other end of the brush to knock out any foreign objects that could be trapped under the spacebar.
Once your happy it's clean turn the laptop on and see if the spacebar works.
If you still have the same symptoms then the keyboard will have to be replaced.
You can use the on-screen keyboard to substitute for the spacebar for the time being.
Good luck.
Aug 12, 2009 | Toshiba Satellite A135-S4527 Notebook
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Pressing spacebar once will make cursor skip 3-5 spaces
I had the same problem on the Logitech MX3200 wireless keyboad. I simply unplugged my receiver from the USB port and plugged it back in. It's not the first time I've had this happen
Jan 07, 2009 | Logitech Cordless Desktop MX3200 Laser...
Logitech 967437-0403 Keyboard Logo
160 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
