Kingston 1GB Secure Digital Memory Card Logo
Posted on Jun 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Card not open in computer & mobile - Kingston 1GB Secure Digital Memory Card
Anonymous
Level 3:
  • Master 790 Answers
  • Posted on Jun 06, 2009
Anonymous
Master
Level 3:
Answers
790
Questions
6
Helped
225243
Points
1965
Hi
maybe you have corrupted files in your SD Card, please try to reformat your card..
Thanks!
1helpful
2answers
How to format my memory card using pc?when i press the data storage mode,it starts formatting the memory card in mobile & the mobile as usb doesn't show up in pc.so how can i format it in pc?
You just need to remove you are memory card from you are mobile and place you are memory card in card reader slot.After that connect that data card to you are pc.Then open my computer there you will find as removable disk right click on it.Then there will be number of option in that select formatting after that select quick formatting then a new window will open telling that all information will be erased.Then give ok then it will format.Thanks for your question.
1helpful
Picture file MENC can't open in my PC
.MENC file extension is a Windows Mobile Encrypted File.
Open this link to read more about .MENC file. It say's there,
"MENC files are designed to be decrypted by the device that created the file. Therefore, MENC files can be transferred to a PC using Windows ActiveSync or Windows Mobile Device Center, but it may not be possible to decrypt the file on the computer. Also, changing the GUID on a MENC file will disable the ability of the decryption program to properly decrypt the file.
To avoid encrypting files, go to Settings ? System or Settings ? Security on the Windows Mobile device and uncheck the box that says "Encrypt files placed on storage cards.""
1helpful
2answers
I have a old Motorola W490 cell phone, with some videos that were saved to the phone itself and not on a SD card. How can I download the videos off the phone & to my computer. I have the USB cable but...
IT YOU DO NOT HAVE PC SUIT FOR YOUR MOBILE THEN YOU CAN USE MASS STORAGE OPTION TO TRANSFER ANY DATA BETWEEN YOUR PHONE AND MOBILE.TO DO SO PLEASE FOLLOW THE PROCEDURE MENTION BELOW.
  1. GO TO MENU> SETTING> CONNECTION>USB MODE
  2. CONNECT YOUR MOBILE TO PC USING DATA CABLE (USB)
  3. SELECT MASS STORAGE OPTION.(IF YOU CAN NOT FIND THE OPTION OF USB MODE THEN SELECT THIS OPTION WHEN YOU CONNECT YOUR MOBILE TO PC THROUGH DATA CABLE.)
  4. OPEN MY COMPUTER AND YOU SHOULD SEE YOUR MEMORY CARD IN REMOVABLE STORAGE DEVICE.
NOW YOU ARE DONE.
YOU CAN ALSO USE BLUETOOH TO TRANSFER ANY DATA BETWEEN MOBILE AND COMPUTER.
THANKS FOR USING FIXYA
My 2gb microcard is not opening in my pc & mobile also. pls help me
try opening in another computer 1st; if it doesnt work out, ur microcard is corrupted.
1helpful
Mobile file open slow
it is happening due to virus
format ur cellphone & memory card after saving ur data in ur computer
always use quick heal antivirus in ur computer
if u r satisfied with my answer then pls vote me
Dell laptop computer don't open mobile memory card
my 1GB gateway meory stick cant not show the items on it.
18helpful
3answers
Write protection in N70 nokia mobile MMC card
there are many things you can do to remove write protection but you have to give rating to me. Here is the first one 1.)go to MY COMPUTER 2.)right click on MMC drive 3.)click on eject. 4.)remove MMC form card reader 5.)again put it back (if at once it didn't worked try again step{2,3,4}
second method is: sometimes your USB port locks it try some other USB port & then put the MMC in memory card. pls rate me thank you
Tryna use a sandisk mobile mate memory card reader...i put it in the computer & its not working..blue light is on but no icos have appeared...please help!!
You may not see any icons o nthe desktop or system tray. Open up My Computer and see if it shows under "Devices With Removable Storage", that is where I access mine. MM85
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
