A WJ Jeep. with 4L I6 but what trans?
please show what lamp is glowing, exactly
do you need an operator guide (glove box) is it lost.
get one an all lamps are identified, the newer the car the more lamps.
and it gets quite overwhemling , those lamps. so dont lose the guide.
park assist disable
other feature? the oper guide will tell you all warning lamps and there
meaning.
the car is feature, rich, RTM
get the opr, guide, if it is lost.
SOURCE: 1996 Jeep Grand Cherokee - Will Not Start or Run
they have crankshaft sencers on the transmission on jeeps. it would be up high on the drivers side on front of transmission. they will cause it to not get fuel or fire and can run then quit.
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://www.howtorepairguide.com
These will help.
Thanks.
It
From
Won't Start?
These will help.
Thanks.
It
From
Won't Start?
Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
These will help.
Thanks.
