It was saying error code 11 so i found fixya and it said to uninstall and now i cant find the page to show how to reinstall
SOURCE: Belkin (F5D7050) 802.11a/ Wireless Adapter
I just noticed that it is a 802.11a/ . "a" wireless products do not work correctly and you need an "a" router to connect to. The "g" protocol is the most common and reliable.
If it is a new adapter, I would return it and get a 802.11 g adapter, not a USB.. they cost about $20.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: my cd driver isn't working code 39. i
When you found that your CD player was not working - did you go to the Aspire website? Most computer companies today can check your system for you - JUST FOLLOW THE INSTRUCTIONS ON THE SITE other than that the possibility of your CD has died and you need to replace it. Not too big a problem keep us posted.
SOURCE: I need microsoft ISATAP adapter #3 driver
you can try this: 3. Still in Device Manager, click Action and select Add legacy hardware. 4. Click next, and select Install the hardware that I manually select from a list (Advanced), click next. 5. Select Network Adapters and click next. 6. Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel. 7. Click next and finish the remaining wizard. The ISATAP is related to Internet Protocol 6. Please check if IPv6[Internet Protocol version] is enabled on your computer to obtain an IPv6 address. however this driver only pertains to ipv6, so your internet adapter should still function properly. if it is, you can do this: Disable but leave ISATAP in the hardware list and go to your manufacturers Website
Step1:
However, try the below steps to fix the issue you are experiencing:
1. Click on Start, type Device Manager in the search box.
2. In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
Step2:
and check for Post SP1 Driver updates for your computers Chipset.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
