Question about Mitsubishi XL1XU Multimedia Projector
Mitsubishi XL1XU Projector
The projector has been sent for repair several times now. The latest problem was with the ballast to correct the lamp ignition. How often does this occur in these projectors and is this a common one for other projectors as well? Is there an explanation of this problem and what causes it?
  • 563 Answers
Hi there
The most common cause for a Ballast to go faulty is power failures & power spikes and off course lightning.
I normally advise my clients to hook up a UPS to the Projector just to make the power supplied to the Projector more even and smooth.
Ballast problems however occurs more than often on any model of Mitsubishi I have found.
Posted on Mar 27, 2008
Lamp light flashes amber without the lamp ever turning on, then projector shuts down in a minute or two
Based on what you're describing, it sounds like a failure in the lamp ballast itself. The projector will probably need to be sent for service.
If you have a spare lamp, that would be the first thing to try. However, if it isn't that, it is likely the ballast.
Mar 15, 2016 | ViewSonic PJ402D DLP Projector
Lamp illumination has a slight pulsation. Lamp was replaced with a factory unit.
The lamp ballast is the problem. I'll bet your old lamp will work when the ballast is replaced.
Jan 09, 2014 | Mitsubishi HC1500 DLP Projector
How to reset mitsubishi VLT-XD221LP projector lamp reset Kumar Salem
Reset of the lamp operation time
1,Connect with the Power cord, and turn the power on.
2,with a signal supplied to the projector.
3,Menu--INSTALLATION--LAMP TIME RESET-and press
ENTER button to reset lamp operation time.
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Oct 07, 2013 | Mitsubishi VLT-XD221LP Replacement Lamp...
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
Automatic power shut off
Hold right left and power all at the same time and it will reset...
Jul 23, 2008 | Mitsubishi XL1XU Multimedia Projector
Projector issue
Hi maxima_90
The only other thing that could cause this once the lamp has been replaced is the Ballast ( lamp's powersupply )
If I could give you a tip , rather replace this part than repairing it , as I have found that the problem comes back most of the time on a repaired Ballast.
May 12, 2008 | Panasonic PT L720U Multimedia Projector
The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
Bright then dark
check bulb life time if it is near end change it.
Feb 14, 2008 | Mitsubishi XL1XU Multimedia Projector
LVP-X3004 Mitsubishi Projector
Problem could be a fan problem or heat sensor or power ballast. Or at a board level a circuit board component failure - IC, capacitor etc Best to have it serviced by an authorised repair shop for Mitsubishi projectors. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Jun 22, 2007 | Mitsubishi LVP-X30 Multimedia Projector
Mitsubishi XL1XU Multimedia Projector Logo
284 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
neOen
Level 1 Expert
Marvin
Marvin
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
