Question about Creative Labs ZEN Vision:M Digital Media Player
Not turning on
No matter what i do the Zen (screen or buttons) will not turn on, the LED flashes when i plug it into to comp and when i try to turn it on nothing happens, it has beenn charging for a total of 19 hours and nothing
  • Anonymous Nov 02, 2007
    mine is exactly the same, it was fine one day, now it wont turn on, it doesnt show up on my lap top when i plug it in, and when its plugged in the power light just flashes blue, what the heck is going on?
  • mfairchild Nov 03, 2007
    One day I was listening to my Zen..and it was on really low battery. After a few minutes it shut off. I charged it by using my computer but it wouldn't do anything. So I bought a electrical socket charger, and charged it overnight. It turned on once, but won't turn on now. This is really frustrating because I haven't had the Zen for very long and have been taking good care of it.
When i hjad that problem i just reseted it a few times and it somehow started to charge :)
Posted on Nov 23, 2007
    Problem Solver:
  • 12 Answers
Have you tried hitting the small reset button on the bottom of the unit with a paper clip or similar object? I have had mine freeze and shut off and not do anything before and this seemed to fix the problem. This has only happened with corrupted or unsupported file types as far as I can tell.
Also, if you got the unit second hand, the batteries may need to be replaced, as lithium polymer batters do wear out eventually and wont take a charge.
Posted on Nov 09, 2007
Won't turn on but will come on when plugged into comp...
push the reset button on your zen .
it should be on th e outside in the edge part .
push it , then try to turn it backk on .
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
I/O error in creative zen mp3
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reboot" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Feb 26, 2009 | Creative Technology ZEN Stone MP3 Player
My zen won't turn on. only the blue light flashes when its plugged in. the screen doesnt turn on. what does this mean thanks
Well you can try this if you still got the zen, press the reste button, dont hold just press it then hold down the power button and it will start up but mine just kept on going black fter a while so i had to put it into recovery mode by doing the following.
Hold down play untill the end
Press the reset button
Hold down the power button
Makes sure you releas the play button last
after that do Reload Firmware i think
then it will delete the firmware make sure you have this downloaded on your computer
its the newest firmware
when you downloaded this plug in your zen into the computer and it should turn on your zen and then say Firmware problem and if it doesnt just put it into recovery mode then plug it in.
Then make sure all application are turned off like Mozzila or the Internet Explorer, then just double click on the firmware and it should fix
Feb 01, 2009 | Creative Labs ZEN Vision:M Digital Media...
The screen won't turn on
All I did was press the small reset button on the bottom of the system.
Dec 27, 2008 | Creative Labs ZEN Vision:M Digital Media...
My Creative Zen won't turn on OR off!
I had the same problem today too. I just stuc a needle in the little 'Reset' hole at the bottom and it was all good.
Oct 31, 2008 | Creative Labs Zen Digital Media Player
Power button
are you sure that is the correct case mite be power button is shot
try turning it on with the cover off... or mite be something isn't connected correctly... lala linda
Jun 01, 2008 | ASUS P5LD2 Motherboard
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Not turning on
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
Feb 10, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
read this:
Dec 12, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
44 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
