Video cards We are a church and we purchased a Dell computer built to run dual monitors for our projectors in the sancturary about 3 years ago.Out of the box we loaded our software and it worked perfectly. The desktop monitor shows the preview panel and the second vga goes to the projector and shows a different picture. We just opened a new location and again bought a Dell and told them we needed the ablility to run 2 independent monitors( One desktop, the other projector). When the computer got here we loaded the software up and was unable to get both the projector and desktop monitor to run in dualview. They sent us a new nividia ge force 7600 gs video card and we have installed it and still not able to view one thing on desktop and something else on projector. Does anyone know if this card will do what we need it too or do we need a different card? Could anyone help me with this issue? Thanks, Paul302-218-8833
  • pgrapes Oct 26, 2007
    Got it working.
Thank you for your input! It was very helpful. paul
Posted on Jan 14, 2008
  • 265 Answers
Your card certainly will support two monitors. It has two connectors and they are accessed by the nVidia software, available from the manufacturer's website. The link to find the latest version is below. You need to select '7 Series' in the second pull-down menu, and in the third you'll have to select your operating system. The software is a bit confusing, but I have the same video card in my computer, so if you need further help, please post your question / results by reply to this conversation.
  • Aimiel Ireman Jan 14, 2008
    If you like, we can set a time, and I'll call you (my long distance is free) to talk you through setting up the PC. Please let me know.
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
I have a Dell 2300MP projector which works perfectly in cloned monitor mode with a 3-year-old desktop computer running Windows XP with an ATI card. I have very recently bought a new desktop running under...
This problem was also faced by me some time ago, i just change the data cable (vga cable) and then it will recognized by system,
i suggest to change the vga cable and try to find the DVI cable if possible to connect the projector to system end.
Hope this helps.
Jan 25, 2011 | Dell 2300MP Multimedia Projector
Will a dell dimension 2100 support dual monitors
Yes it will but that will also depend on your graphics card to a degree.
To do it properly you need to install a new graphics card and disable the on-board graphics card from the bios.
Your new card should support std VGA as well as DVI
DVI is also capable of being hooked up to many large screen tvs
Aug 20, 2009 | Dell Computers & Internet
Image not being displayed through projector
make sure the resolution matches. the projector uses 640x480.
May 27, 2009 | SharpVision XV-S96U Multimedia Projector
No display on Windows Vista need driver?
Make sure that the settings in the new video card are actually set to run both monitors.I see this happen in my comp. repair shop quite often. It is a common mistake.
May 04, 2009 | Dell 1703FPT 17-inch Flat Panel Monitor
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Dual Monitor Problem
Go to Control Panel, select Display, select Settings - change the drop-down to select which display is Primary?
Dec 28, 2008 | Computers & Internet
How to run monitor and projector same time?
You would have to have a dual head video card (two monitor connections) or have two regular video cards, or use a VGA splitter. If you do it through a video card, once you have them installed, go into the settings tab on the display properties and it will show multiple monitors, simply click on the second one and check the box that says "extend my desktop..."
Good Luck!
Dec 05, 2008 | InFocus LightPort (NP-LP98-HT) for PC
Dell 410XPs + Dell 3007WFP monitor issues
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Open Questions:
Computers & Internet Logo
278 people viewed this question
David Payne
David Payne
