Question about Dell Axim X51v Pocket PC
Dead - no response
Help
My Axim went dead on me with no warning. then I noticed the battery cover had gone missing. When I plug it into the charger the green light comes on on top, but it still has a black screen and will not respond. As soon as I take it out of the cradle charger, the green light goes off and it is dead.
Do I need the battery cover for it to operate? Or is it just a coincidence?
Any suggestions would be appreciated. of course my one year warranty just ended!
  • 1 more comment
  • mjknagy2 Oct 27, 2007
    Thank you Zoandar,
    I so appreciate you going out of your way to help me!
    You are right, the Axim needs the battery cover to operate.
    Of course, after 45 minutes on hold with Dell, I was told they do not sell replacement battery covers - so, my Axim is unuseable?? Typical Dell service in my experience. And I also believe the battery cover on the Axim is designed poorly since the essential battery cover can easily be lost since the lock latch is very easy to bump open.
    Replacement batteries and covers can be found at http://www.hypermicro.com/product.asp?pf....
    Thanks again
    Maureen
  • Drupinski Feb 26, 2008
    My Axim will not turn on because I have misplaced the battery latch
  • princesinva Apr 01, 2008
    We are having the same problem.....lost the cover and now it doesn't work. Could someone elaborate on the use of scotch tape or fingernail polish. We don't quite get it.
Just battled the same issue of the back door being missing and the Axim X51v not turning on and/or waking up from sleep mode. After reading the above posts, I wedged a couple of pieces of a paper clip onto the above mention switch (right side of left rectangle - backside bottom) and "poof" it's alive.
IT'S ALIVE I TELL YOU! Thanks for the above posts.
JNeedlez
Posted on Nov 14, 2008
I have the same problem and I got a perfect temp fix for you all. I took a pen cap and looked for a bigger pocket clip and I cut a tip off and I then placed it in on the switch and make sure the piece you cut is small about 2-3mm. Once in place you slide the lock over and the switch will be held down until you get a new cover or in my case until my brother can find it in his moving boxes.
Posted on Sep 21, 2008
Yes, its all true. Reading on different forum gives you two pretty good solutions to the problem. The first one (wich I dont really like) is to put a couple of layer of scotch tape on the leg that activates the battery latch switch. The second feels more permanent and it involves putting nail polish in several layers on the leg. That way it wont glitch on you.
Posted on Mar 08, 2008
  • 3 Answers
Hi, I am looking for a battery related problem solution on my own Axim X51v, but it is different than yours. One thing I wanted to share with you is that I know if the battery cover lock button is not in the locked position (slid to the right) it activates the "battery door switch". I have occasionally received error messages on the Axim when I turn the screen on and it has missed sounding an alarm. it will say "the battery door switch was open, so the system was put into "sleep mode" to preserve data from being lost" or something like that. So I believe that the position of the latch is crucial. In my case, I think the switch gets dirty. When I get the warning, I slide the switch back and forth a few times and then it stops bugging me for sometimes several months.
So, if you do not have the cover on, then your latch is probably open, and the door switch will be sensed as open. I am not sure what Sleep Mode really does, but I'll bet it will make the Axim appear dead. At the very least, try sliding that latch back to the right. However, I would replace the door, because only friction actually holds the battery in place unless the door is on. It could fall out when you least expect it. Then I think you would lose any unsaved data, and if your internal backup battery was not up to the task, you could lose everything. I hope this info helps you out.
I'll go post my own problem now.
Posted on Oct 27, 2007
  • Asper G. Illus Oct 27, 2007
    Hi again. I may have the solution in better detail. I was just reading on another forum devoted to Axims where a member said "the battery cover needs to be installed to press on the battery door switch". So I thought maybe I was wrong about the latch activating the switch. Maybe it is the little latching legs on the cover itself that activate the switch.
    I decided to get brave and closely examine my own Axim, and I can now tell you that if you look very closely inside the LEFT pocket that latches the cover (to the left of the sliding latch button) you will see there is a tiny rectangular raised spot in the bottom of that pocket, at its right end. You will not see that in the right pocket. The bottom of the left pocket will move up and down slightly, as does that raised bump upon it. I believe the actual battery cover switch is UNDER that left pocket. To prove it, I tried to turn on my X51 with the cover removed, and it won't come on. Then (requires a bit of acrobat here) I carefully pressed upward against the apparent switch activator with the tip of a letter opener, while holding the Axim so I could see the screen, and pressed the power button. It instantly came on. I release the letter opener, and it instantly went black again.
    You need the cover installed to run the Axim.
    Zoandar.
2000 cavalier. dead battery. poss short.
Jumping a dead battery is a dangerous practice
You have to fully charge a dead battery before
putting it back in service
Have the battery tested
Get a fuse cover from a salvage yard
Jul 26, 2013 | 2000 Chevrolet Cavalier
My dell axim x50v will not turn on
To everyone that's having problems with not booting up or the back plate battery cover warning messages on your Dell PDA, I think I've found the answer, I have 2 Dell's PDA's, 1 a X51v & the other a X50v, I was having problems with both of them (1 had battery cover warning messages & the other had a screen freezing) so I stripped the 2 of them down when I had both rear shells together I noticed that the small piece of sponge that Dell fit to the latching mechanism one was on the far right of the latching plate on one & the other was in the middle of the plate, I looked to see which shell belong to which PDA & the one I was having problem with battery cover warning messages the sponge far right, so I swapped the back shells around & booted it up BINGO!!!!! problem solved, I'm fairly sure the SPONGE SHOULD BE IN THE MIDDLE OF THE LATCH PLATE, if I'm right Dell engineers & executives should be shoot, such a simple fix why didn't they let owners know about this. This has got to be easier than trying to bridge the switch contacts or rip the switch off the board, give it a go guys, Please let me know if it works on your PDA. I will upload some photo should any of you guys need.
welshcob
Nov 20, 2012 | Dell Axim X51v Pocket PC
My battery cover warning keeps coming on It apears to be lose.
I had exactly this problem before. It seems that the extruding bits under the cover were a bit worn so that they failed to consistently activate the sensors below. I cut two pieces of sticker and stuck to the moving parts below and the problem has gone (for now).
Jun 07, 2009 | Dell Axim X51v Pocket PC
Dell axim x 30 backup battery wont work
--This is a suggestion. I can not be certain given I have not worked on this device. --
Sounds like the backup battery is dead and needs to be replaced.
Researched The battery, and it is a standard flat-cell available at Radio Shack.
Taking the device apart will void the warranty.
The device is assembled in a standard click-tab and possibly some small hidden screws.
A plastic screw-driver or non-marring wedge tool is best.
Simple work your way around its edges until a gap forms and gently feel towards a portion that will not separate. Get a tool in there and gently pry away from the device to disengage the clips, rinse and repeat.
Upon removing all the tabs, remove the back panel slowly to assure that there are no wires connected to the panel itself, you should see the battery.
Apr 14, 2009 | Dell Axim X30 Pocket PC
Dell Axim x51v that will not power on.
Assuming the battery is not dead, try taking the battery out for a few seconds to be sure the PDA is turned all the way off. Put the battery back in and close the back. Use the stylus to hold the reset button in (on the back) while you press and hold the power button. If the battery is dead do this while it is connected to the charger. It should diplay a message telling you to press the mail button (to the left of the cursor control button) to the reset to factory defaults. Caution this will erase everything in the built in memory including any programs you installed after you recieved it.
Hope this helps
Dec 15, 2008 | Dell Axim X51v Pocket PC
Stopped turning on, charge light appears when plugged in...
try removing the battery and plug in AC power only and power up, sounds like you may have shorted the battery
regards
Nov 24, 2008 | Gateway CX2610 Notebook
Phone dead
I am guessing heat can only come from discharging the battery in a non-intentional way. Short circuit or something internal.
Did you plug it into something besides the connector it came with?
An FM transmitter for the iPod killed mine.
Hard reset, wall charging, USB charge, iTunes restore, replaced the battery ... still dead.
Considering how hot it gets, (could be a fire hazard?) surprised Apple doesn't issue a notice or warning.
Caveat emptor, going back to Motorola.
Mar 13, 2008 | Apple iPhone Smartphone
Dell Axim x50v - Battery Latch Problem
Hi Guys
Here are some photo's of the before & after showing where the sponge will be when your Dell PDA is faulty (not booting up or battery latch warning messages & where it needs to be repositioned to, the photo's should be self explanatory, I used some double sided tape to refix the sponge but super glue might work but don't blame me if it runs into the latch mechanize & gluing it up for ever, this does really work & better than messing about with the PCB. I have posted more details on this forum just search for the title ""Why do I get a battery latch open warning Axim x51v"
Welshcob
Sep 09, 2007 | Dell Axim X50v Pocket PC
Non-Responsive PDA
You may have to do a hard reset. You hold one finger at the power and the other hand hold your stylus and his reset. This technique is applied to most PDA.
Aug 09, 2007 | Dell Axim X51v Pocket PC
Dell Axim X51V
I have the same problem. I've found that the Innopocket magnum case will hold the cover in place and pretty much stop it doing this. Unfortunately, the case won't fit if you have an extended battery. I've tried taping down the cover with some success, but the hard case worked better.
Jan 25, 2007 | Dell Axim X51v Pocket PC
Dell Axim X51v Pocket PC Logo
1,108 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
