I have got an electric fire Place that blows out hot air, well after about 5 mins it stops blowing out hot air and it blows out cold air, can any one help me fix it?
More than likely, the heater element is overheating and the overload switch is turning it off. It could just be a case that the heating element needs cleaning. As they do become clogged with dust and lint, because they take in cool air at floor level, heat it and send it back out. You didn't mention who the manufacturer of your electric fireplace is, but they all work just about the same way (badly, most of the time). Turn OFF the Master On/Off Switch, unplug the fireplace from the wall and leave unplugged for 12 to 15 minutes. Now, would be a good time to clean the interior, if you want to under take it. Plug the heater back in and turn the Master On/Off switch to the On position. Turn ON and set the heater control. If it returns to normal operation, the problem is solved. If the unit continues to have to be reset (if it's a Dimplex) turn the Master Switch Off, unplug the unit and contact Dimplex USA, Technical Service at 888-346-7539 for more information.
Hope this helps solve the problem.
