Is your HP printer Paper tray stuck closed due to broken or some other technical issue? If your HP Printer has stuck paper in tray, then you need to follow these troubleshooting methods to fix paper jammed in HP Printer. Otherwise you need to talk with HP Printer experts through Free live chat.
Take the paper out and inspect the slot that it fits in. There is a lever switch there. If it is broken or stuck you have found the problem. Broken switches mean that you need to replace the whole printer.
The hinge underneath could be broken the only way to fix this is to remove the plastic hinge.. You will need to unplug the printer and examine it, the broken hinge is likely to be impeding the lid from closing,
What error number is show on printer display? May be a software problem, try to reinstall the printer software. If a ink cartdrige is missing or malfunction all the printer function (including scanner) is unusable, you need to replace the broken cartdrige!
If i not paper in the printer,you must unzip the printer,the paper sensor is skipped.The paper sensor is under the scanner in the middle of printer.If the sensor id broken you need to replace,if the sensor is skipped try to put in the rigth position.Good luck!!!
Error code 5C00 means purge unit is broken. You need to bring the printer to the service center to get broken purge unit replace. I hope this short information help you. Thanks.
Find more printer troubleshooting only at: Printer Clinic
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
