HP Laserjet 1020: False paper jam
Every time I try to print now with this printer, it tells me there is a paper jam.  There isn't, but I follow the instructions anyway.  The problem recurs.
  • 1 more comment
  • sunnyD2008 Apr 09, 2008
    The misfeed light keeps blinking, but i checked all possible jams, it just keeps blinknig
  • Anonymous Jun 04, 2008
    Same thing here with the AR-M277
  • Matt Cardier Jun 09, 2008
    I have the same problem. I can print one sheet of paper, after which I get a "paper jammed" message. I've tried varying the amount of paper I put in, aligning it better etc., but it makes no difference. It's a great scannerr and fax, but useless at printing.
  • 1,218 Answers
Hp false paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Oct 15, 2010
Culprit could be a worn (or non-functioning) pick-up roller. Most printers will report a paper jam even though it hasn't actually fed any paper.
Good Luck.
Posted on Jan 14, 2008
It's most likely a sensor problem. I suggest you exchange your printer.
Posted on Nov 14, 2007
This is most likely a sensor problem. I suggest that you exchange your printer for a new one.
The hp laserjet 1020 the front cover door open or the toner cartridge is missing
this issue for
1 If this printer paper jam or any sensor in transfer unite or resistance unit displace or broken
Apr 12, 2017 | HP LaserJet 1020 Printer
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Paper jam in hp laser Jet 1020 printer
Sir/Madam
I suggest You Please Watch Below YouTube Link URL To Fix Your HP Printer Error:
http://www.youtube.com/watch?v=M4BJ-0A029M
Or
In case You still need Online Support For Hp Printer Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 1020 Printer
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
My laserjet 1020 has a paper jam output message, i followed the instruction that appeared on the screen, but still, the message appear when i tried to print, there is also a red blinking light
Try to press the reset button on your printer if did not works just try to download the reseter of your printer in HP Laserjet 1020 at the HP website. Because your printer have a lifespan printing; example if your printer have a 100,000 copies to be print so you have aloud to print not more than 100,000 copies. That's why need to reset your printer using the reseter program by HP.
May 26, 2010 | HP LaserJet 1020 Printer
Self print
Hi all of you
follow this steps
1. Power off the printer.
2. Press and hold the Go button.
3. Power the device back on while holding the Go button for 20 - 30 seconds.
4. Release the Go button.
Hope this fix your problem
thanks
Hamedo
Nov 21, 2008 | HP LaserJet 1020 Printer
Problem with HP LaserJet 1020 Printer
Hi all of you
  1. check paper sensor.
  2. check that return every thing proper cartridge and the door.
  3. move the gear system manually.
Hope this fix your problem,
thanks
hamedo
Nov 17, 2008 | HP LaserJet 1020 Printer
Will not print
how to replays tephlon sheet for hp laserjet 1020 printer
Nov 15, 2008 | HP LaserJet 1020 Printer
Have paper out jam
hi,
maybe your separation pad is worn out that's why it can't pick up paper which causing the paper jam...
rey
Oct 21, 2008 | HP LaserJet 1020 Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
1,418 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
