Question about Acer Aspire 5630 Notebook
Acer aspire 5630
I can't get the camera attached to the laptop working. How can I do this?
  • nkprincess22 Oct 26, 2007
    well it's not the camera that i attached...it's the camera that came with the comptuer that is acutally on it. i can't seem to figure how to work it.
    thanks for trying though.
  • 1,006 Answers
Do you have installed the original driver???
if yess soo :
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Oct 26, 2007
Aspire 5630 orbicam.exe has stopped working
try to reinstall the drivers or roll back the driver
Oct 22, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Where can i download acer aspire 5630 camera windows 7?
There are no actual drivers for this webcam in windows 7, you can use the vista drivers in compatibility mode. Get them here: http://www.laptop-software.com/acer-software/acer-aspire-5630-drivers-softwares/
Mar 24, 2011 | Acer Computers & Internet
I need Camera Driver,ethernet controller,pci modem for acer aspire 5630 as soon as possible please
I take it you have use of another computer or the wifi is still working on your aspire 5630. This link has all the drivers for that make and model of laptop. Hope this gets everything back to normal again. http://support.acer-euro.com/drivers/ftp/ftp.html
Sep 12, 2010 | Acer Aspire 5630 Notebook
I have a Acer Aspire 5630 laptop. I can't seem to
make sure ur wifi button is on.if yes & it is not working then update ur driver.
Jan 05, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
My acer orbicam on my aspire 5630 has stopped working it says it is being used by another program please help.
just remove the device form device manager\hardware and uninstall the camera driver and install it again.
Sep 07, 2009 | Acer Aspire 5630 Notebook
I need an acer aspire 5572awxmi camera driver from my laptop
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Acer-Aspire-5630-Webcam-Driver-944.shtml just click this link and download the required driver.the model number is different but it will support your laptop and camera. thanks.
Jan 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Web camera is not working
Here you go:
  1. Press ‘Alt + F10' to start eRecovery Management.
  2. Enter default password of 6 zero's. Example: 000000
    Select ‘Recovery Actions' and click ‘Next'
  3. Select ‘Reinstall Applications/drivers' and click ‘Next'
  4. On the left hand side of the newly opened window select the following: Windows XP
    ? Driver
    ?Camera
  5. On the right side of the same window, click ‘Install Camera Driver Now'
  6. The unit will reboot after the installation is complete.
Please rate my solution when possible....!
Good Luck....!
Cheers
Jun 14, 2008 | Acer Aspire 5630 Notebook
Acer Orbi Cam Aspire 5630
Try to unplug and plug again the camera cable. it's under keyboard.
You have to open the power cover and remove keyboard screw, you can see the wire that connect to mainboard.
If this way don't work, try to uninstall the camera application and installed again, if this is still don't work, Reload the OS.
Jan 22, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
