Question about Toshiba TLP 261 Multimedia Projector
Out of focus...
I have a Toshiba TLP 261 and the problem I have with it is an 'out of focus' image projection at the top only!  I really don't know anything about this projector, but I did notice the focal lens' housing seems to be a bit skewed.  Is this normal?  Please let me know asap!  Thanks
  • 682 Answers
Http://www.projectorcentral.com/pdf/projector_manual_1798.pdf.
please read manual above.
Posted on Mar 21, 2008
SOURCE:
UPSIDE DOWN IMAGE TLP261 LCD
You need to get into the menu, there is an invert image option as the projector can be mounted upright or upside down depending on the mounting of the projector
Mar 08, 2012 | Toshiba TLP 261 Multimedia Projector
Hello. How do I invert the image on a Toshiba TLP-2000 EDU Projector. Many thanks, Paul
Go into the setup menu.
One of them is the picture or positioning menu.
There are normally 4 options,
front projection standard / inverted.
rea projection standard / inverted.
dont move the projector whilst on or bulb is warm as bulb is very fragile at that time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 19, 2011 | Toshiba TLP-XD2000U Mobile Projector
I have a toshiba tlp 770 projector. The image is not sharp and i bought it on ebay. How do I make the image sharper?
first, reset the settings to factory default. if you are using it with a computer, make sure it matches resolution. native for the projector is 1024x768, but maxes at 1600x1200. and the input is analog, not digital. if you are doing video, make sure you are on the correct video input. it does do hdtv, but not 480p or 480i. if none of this helps and the focus does not work, check case for signs of damage. maybe the previous owner dropped it and damaged something internal. last possibility: clean it out using compressed air. take the top off if necessary. since it is an lcd projector, dust and dirt build up on lenses and light filters causing them to burn. remove the lamp and look at the fly-eye lens inside the lamp housing. if you can see the one behind it, check for burn marks. there may be parts that need replacing.
Aug 15, 2009 | Toshiba TLP-770, TLP771 Replacement...
Toshiba TLP XD-2000
There are two things it could be...
First, how far are you trying to run the cable for? When you run longer distance a humbucker might be needed. Or it means that the internal distribution output has bad vertical and horizontal connections.
Jul 21, 2009 | Toshiba TLP S30 Multimedia Projector
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
LP540 Infocus PRojector
first try a new vga cable. if the problem persists, go into the menu and find the settings to that computer output. chances are it's on component. set it to vga. if that doesn't help, reset back to factory default, then set it to vga.
May 01, 2008 | Toshiba TLP 261 Multimedia Projector
Toshiba TLP 261
What do you mean by red filter? There is no red filter in this unit.
Apr 08, 2008 | Toshiba TLP 261 Multimedia Projector
Projection Problem with Toshiba TLP 261
If its only in the lower left corner sounds as somethings blocking the lamp from the lcd These sets dont use a degussing coil so we know its not a magnetic problem Check and see if something crawed inside the set and is blocking a bit of the lcd?? ar could be dirt or dust too??
Mar 28, 2006 | Toshiba TLP 261 Multimedia Projector
Camera Problem with Toshiba TLP 261
hi Document camera image is blurry: -The lens is dirty - Clean the lens with a blower or lens cleaner -The picture is out of focus - Focus the picture by turning the focus ring -The light is not on - Turn on the light check user manual for more details: http://www.fixya.com/BrowseManual.aspx?mnlid=5662&prdid=147420&__PAGED_=1 good luck
Mar 27, 2006 | Toshiba TLP 261 Multimedia Projector
Toshiba TLP 261 Multimedia Projector Logo
123 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
