Home | LG | L1915S 19" LCD Monitor | Blinking monitor
LG L1915S 19" LCD Monitor
Problem for LG L1915S 19" LCD Monitor
Blinking monitor
By john_sungh1 on Jun 06, 2009
well, when i use my computer, the monitor keeps blacking out, then become normal again. the monitor's on switch LED is on, so i know that the monitor isn't turning on and off. any idea why this is happening? perhaps backlight problem?
Sponsored Links
Best Solution
posted on Jun 06, 2009
Very Helpful)
blubanshee
Rank: Wiz
Rating: 94%, 30 votes
Hello, It sounds like you have a capacitor problem. It was about two years ago that some bad capacitors from china was purchased by several of the big monitor manufactures. These capacitors almost like clockwork start swelling after the monitor is about a year to a year in half old. The biggest manufacturer that this happened to was Gateway and you can do a Google search on just about any (FPD2185W Gateway Capacitor Problem) and the internet is full of unhappy people. They were not the only ones that purchased these bad capacitors. There are alot of how to guides on replacing them yourself if you have a little mechanical knowledge and a soldering iron. You can also find several guys on e-bay selling the power inverters with new caps or offering to fix yours. Just go to e-bay and type in Power Inverter for monitors and you will see. If this is your problem the monitor will get worse. They start not powering up after you restart the computer. But the power button will still be lit up. Then after a while it will finnaly come on. I hope this info helps at least point you in the right direction for research.
Have a great weekend
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
motleycrue76
Rank: Master
Rating: 75%, 5 votes
sure sounds like a backlite prob. i dont know for sure if the lite can be replaced on that unit or not
Was this helpful?
Yes
No
Popular Solutions for LG L1915S 19" LCD Monitor
Questions and Unsolved Problems for LG L1915S 19" LCD Monitor
Do you recommend LG L1915S 19" LCD Monitor?
Answer
Answer
when i press power buton computers, on/off led just blinks once,cpu fan turn few times and stop,... (More)
Answer
my 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this... (More)
Answer
what value does R106 have. Since mine is burnt out I need to replace it
Answer
vertical line in the left side of the screen
Answer
I used the autoset feature and it increased the width of display. Now I cant find anything to... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG L1915S 19" LCD Monitor:
Top Monitor Experts
Rank: Guru Guru
Solutions: 418
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
