Question about Farenheit CLX760-2 Car Audio Amplifier
One channel only
Both fuses are good still only gets one channel so all wires are hooked to one side
  • 631 Answers
Try the following:
Swap the RCAs at the input. If the dead channel follows the RCA signal, check the signal source and cabling.
Move all controls and switches to see if the dead channel makes any noise. If so, a dirty switch may be causing the problem.
If neither of those help, you may have a blown power supply for the dead channel. Look at the 3 legged devices clamped to the heatsink. Do you see any that show signs of damage or have black soot near them?
Posted on Oct 25, 2007
My rear speakers won't work in my 2001 Malibu. Stock system and wires to speaker okay. fader set Correct. Could it be speakers are junk?
Get a known good speaker an hook it up in place of the old ones an see if it works , if it does the old one is no good . Now if it doesn't work the radio isn't set correctly or that channel of the radio is blown .
Oct 23, 2016 | 2001 Chevrolet Malibu
2004 escalade speakers work but not left side balance on deck is ok all chiming sounds are from left side Are there fuses on central amp Fuses in hood ok Fuses in dash ok
If your wires are hooked up correctly then it is possible you have blown a channel in your amp or head unit , the amp does have its own fuse but most do not have a fuse for each channel it either works or doesn't . Only other possibility is somehow the amp has been switched to mono .or "bridged" these settings are used when the amp powers only one channel or a subwoofer
Oct 13, 2015 | Cars & Trucks
I have my cb grounded and a wire ran to the postive side of my battery terminal and the antenna wire ran and my cbs channels wont come up we thought it was jus my cb so we hooked another up and it did the...
Here is the deal, even with out antennas hooked up, you should get at least your channels on your cb showing, no of course you would have all noise and distortion with out antennas hooked up. And sense you hooked another cb up with same results it tells me, number one, it is not most likely your cb. If your channels are not even lighting up, then this tells me it is not getting power. I know you said that the cb is grounded, and there is a wire ran to the positive post of the battery. What I would do first of all make sure proper wire on cb is grounded and not reversed accidentally, but what i believe is your not getting power to the unit, if it was properly installed, there should be a inline fuse from the cb radio to the positive post the wire is connected to on the battery. I believe there is a inline fuse that is blow, or not a good connection on the post of the battery. To test this theory, take a long piece of same size wire gauge, and run direct from positive on battery to positive post on battery, of course making sure that the proper wire off the cb is grounded (must be grounded to something metal, might find different spot to ground the radio if not for sure on metal) If you get lights going on then on radio, then your problem, was not a good connection or inline fuse on positive wire that maybe you didn't see was blown. Let me know Mike
Aug 26, 2011 | Radio Communications
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
I hooked everything up on right the wireing and stuff..the ground cable seems fine i got a red wire hooked to the positive side of the battery. everything seems ok. The amp itself came on a couple of...
Issue With Pre initial Rom Fail To Voltage Routine Check Cause... Static on The Chip Unit Posibility Security Relais Wont click On.. Do do so check for Fuse or red push botton over load security Braker at the back of your unit.. if your fuse is good Well Open the case and surch for more fuse inside of the unit Make shure the unit is unplug from the wall...Then check The voltage on the Transformer to make shure you have the right voltage then check The Regulator The Coil and Capacitor If your not shure Well send it to a Reapair Shop it your best choice Amp cant be dangerous for hazard shock....Good Luck
Sep 23, 2010 | Crown MA-5002VZ 2-Channel Amplifier
Hello. I have an Ultra Linear Amp - UL724 model. I am wiring it up to play in 2 channel mode - in stereo. I can only get one channel to work - the left... I swap the rca cords, still only the left side...
YOUR METHOD OF TROUBLESHOOTING USING THE PROCESS OF ELIMINATION IS RIGHT ON AND PERFECT. IT INDICATES A BAD AMPLIFIER CHANNEL. I KNOW THIS SOUNDS ODD, AS YOU HAVE TWO OF THESE NOW. IT IS RARE, BUT I HAVE SEEN INPUT CONFIGURATION SWITCHES WIRED BACKWARDS, SO THE ONLY THING LEFT TO DO IS TO HOOK UP THE BAD CHANNEL TO ONE SPEAKER ONLY, BY ITSELF. THEN TAKE ONE RCA ONLY AND PLUG IT INTO ONE RCA INPUT AT A TIME. THEN MOVE THE INPUT SWITCHES AND REPEAT THIS PROCEDURE UNTIL YOU HAVE TRIED ALL SWITCH COMBINATIONS AND ALL INPUT JACKS. WHAT YOU ARE TRYING TO DO AT THIS POINT IS TO DETERMINE IF THERE IS ANY RCA JACK WITH ANY SWITCH POSITION, THAT WILL ALLOW YOU TO GET OUTPUT FROM THAT CHANNEL. IF AFTER THIS TEST, YOU STILL HAVE NO OUTPUT, THEN NO MATTER HOW ODD, IT WOULD INDICATE THAT YOU DO IN FACT HAVE A SECOND DEFECTIVE AMPLIFIER. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 07, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
HOW TO FIX A BLOWN CHANNEL?
The power supply appears fried and possibly one or more of your output channels. Unless you are good at repairing this sort of thing then I would suggest you save your self a lot of hair getting pulled out in frustation and go to a repair guy and let him pull his hair out instead. Good luck.
Apr 22, 2008 | Kenwood KAC-729S Car Audio Amplifier
Farenheit CLX760-2 Car Audio Amplifier Logo
71 people viewed this question
Top Farenheit Car Audio & Video Experts
Martin Clarke
Martin Clarke
afairman1927
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
