Cars & Trucks Logo
A
Anonymous Posted on Jul 05, 2017
Glow plug light
My glow plus light now behaves differently on my 91 300D - before I used to turn the key, the light would glow for about 20 seconds and I'd start the car. Now I turn the key - the light does not illuminate until about 20 seconds, and then it comes on - for about 40 seconds. Now I can't get the car to start at all. All I get from the exhaust is black smoke, and the engine behaves like it wants to start... but never gets running.
ski84060
Level 1:
Problem Solver:
  • Contributor 22 Answers
  • Posted on Jul 11, 2017
ski84060
Contributor
Level 1:
Problem Solver:
Answers
22
Questions
Helped
9224
Points
36
I have an 83 300SD. Have you actually tested the glow plugs? You can remove and with a jump wire or even battery charger test to see if they are working. Attach negative to the body and + to the tip. Be careful they get HOT. If they are working (test them ALL because even if 1 or 2 are out it can cause hard start) make sure you have power to the plugs themselves. Maybe start there to make sure the relay is working. Test light while turning key on (may need a helper with this).
5 Related Answers
Anonymous
  • 422 Answers
  • Posted on Aug 26, 2008
SOURCE: 1999 1/2 vw tdi jetta
glow plug relay is going out
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Nov 05, 2008
SOURCE: 2002 Jetta TDI has no power to glow plug buss at startup
replace the relay but check connections first as often connection get hot and corroded.failing which buy a push button switch use a relay and and some heavy wire to and from relay to the heaters and work them manually.you could try seperating the relay and cleaning the connections inside.
Anonymous
  • Posted on Apr 22, 2009
SOURCE: Engine starts after about 20 seconds
my 215000mile Audi a4 starts immediately every time. Very likely to be timing related, especially if it was okay before the belt change. Hard starting for slightly mistimed engines is a known problem.
bs77bird
  • 144 Answers
  • Posted on Sep 01, 2009
SOURCE: 02 VW Jetta TDI with ALH engine glow plug
this is a common problem for these cars glow plugs go bad like spark plugs however the smoke would lead to bad mass airflow meter. it is not telling ecu corrcet miss. disconnect mass airflow meter. when cold see if this makes it start better. it should would means you need new m.a.f. glow plug issue take a test light place clamp on positive of battery then pull off glow plug connectors place tip of test light on glow plug the bad one will have a dull light unlike the good one which will be brighter. will need new plugs and wire harness four **** connectors and wire striper and crimper will fix concern good luck
anthony ventura
  • 180 Answers
  • Posted on Mar 19, 2010
SOURCE: F250 Diesel engine won't start in cold weather
check your glow plug relay! located on the right side head
How do my glow plus work we you turn key
when you turn the key on a light on dash goes on and the glow plug relay supplies power to the glow plugs for a certain amount of time, then the dash light goes off and you start the engine.
7.3 diesel some times it will not start for about 20 min. then it will start like nothing is never wrong.it docent send any code. hot / cold no difference
Is there voltage the glow plug relay when the key is first turned on, battery voltage on either side of the larger lugs. If so check the glow plugs. If not check controller.
Why does my 2004 (Land cruiser) PRADO 3000 Turbo Diesel 5sp- have issues starting when it's cold? It turns over and over does nothing, then when it starts, I get a big plume of smoke, then it idles rough...
glow plugs are activated if look on the dash when you turn the ignition just before cranking and you should see a light that stays on for several seconds then goes out and then you should crank the engine ! sometimes when its really cold or the glow plugs are worn try turning the ignition on and off each time light goes out 2 or 3 times to get more heat on the plugs then start ! if this doesnt work then glow plus and system needs checking !
Starting issue, I have a 1993 ford f250 7.3l pre powerstroke. I started the motor and it stalled out like there was a short, now when i turn the key my glow plugs do not fire and wait to start doesnt show...
On some Models the glow plug Relay does not have an integrated Power Relay. This means there is a second Relay before the glow plug Relay that feeds it power.
You should check the wires running to the glow plug Relay for power with the key ON. Check some other wires off of the Ignition switch to make sure your 20 year old Ignition switch is good.
There are some sites which show vehicle wiring. Autozone has a free section after Registering your vehicle but it takes a little sorting through the Help section. There should be a fuse to protect the above Relays.
Make sure you find the Diesel-equipped wiring circuit. Diesel ignitions are different from gas units.
When i hold key on,glow plug light never turns off but it starts and runs ok.light used to go off after 1 second
Sounds like the GPCM needs to be scanned for codes. There were issues if the truck was jump started with the key on. The GPCM would stick and command the glow plugs on to long causing damage to the glow plugs themselves, resulting in possible costly engine repairs.
By boeinga1 on Nov 17, 2010 2001 VW Diesel Golf TDI. Car started no problem. Drove to gas station. Stopped for gas. glow plug light wouldn't come on, engine wouldn't start, engine turning but not starting....
i think glow plug replacement needed. ever used starting fluid in cold to start?try this, next time no start, cycle your key and let the light come on, wait till it goes off, turn key again until light goes off, if you have to do this more than 3 times, and it runs fine, replace the glow plugs only then. thank you for choosing fixya.com!
2helpful
2answers
7.3 Liter Ford Diesel
check glow plugs wait a little longer beforecranking after light has gone out
1helpful
Glow plugs causing starting problem
if you need connectors and terminals for the glow plug connections under the valve cover, Ford sells then so you don't need a whole $600 harness.
info for your use
Section 03-07B: Glow Plug System 1996 F-250, F-350, F-Super Duty Equipped with 7.3L Diesel Engines Workshop Manual
DESCRIPTION AND OPERATION Glow Plug System The 7.3L diesel engine uses a glow plug system which preheats air in the combustion chamber to improve cold engine starting. The system consists of eight glow plugs, the glow plug control module (12B533), powertrain control module (PCM) (12A650), engine oil temperature (EOT) sensor and barometric pressure sensor (BARO sensor) (12A644). The glow plug system is electronically controlled by the powertrain control module. The powertrain control module energizes the glow plugs immediately after the key is placed in the ON position and then determines how long the glow plugs will be on according to the engine oil temperature and the barometric pressure. The required time for the glow plugs to be energized decreases as the engine oil temperature and barometric pressure increase. The glow plugs are self-regulating, and the powertrain control module controls relay ON time. The powertrain control module protects the glow plugs by energizing them for short durations if the battery voltage is abnormally high.
Possible Causes: Insufficient glow plug ON time will not allow enough heat to accumulate in the combustion chamber to easily facilitate starting. If the glow plug system ON time does not meet any of the specifications in the accompanying chart the problem is most likely a faulty wire harness connection, ground connections or glow plug relay.
If the glow plug resistance to ground is high, the most likely causes are an open UVC (under valve cover) harness or open glow plug.
Relay Operation
Install a DVOM on the glow plug feed side of the glow plug relay (large stud with two wires connected). Turn the ignition key to the ON position but do not attempt to start. Note the time in seconds from when the key is turned on and the glow plug relay energizes until the glow plug relay de-energizes. The glow plug relay makes a loud click noise which is easily heard when it energizes and de-energizes. The dome light will dim and the dash voltmeter will dip when the glow plugs are drawing current from the battery. Compare the times measured to the table (time will be affected by engine temperature, battery condition and vehicle altitude). The voltage at the glow plug feed terminal may vary from 9 to 12 volts depending upon battery condition.
If battery voltage not present check for B+ at power supply terminal (terminal with single large wire). Power for glow plug power supply is supplied from starter relay through two fusible links at solenoid.
Glow Plug Operation
Disconnect all of the glow plug/injector harness connectors from the valve cover gaskets. With the pigtail installed, measure glow plug resistance to ground (preferably B-). A resistance measurement of .1 to 6 ohms indicates a good glow plug.
Glow Plug Harness Continuity
Measure for continuity from the connector harness to the glow plug feed terminal on the glow plug relay. Resistance should be less than 5 ohms.
Incorrect measurements will result if all glow plug/injector connectors to valve cover are not disconnected.
Glow Plug Relay The glow plug relay (12A343) has a plastic base and two mounting bolts. It is operated by the powertrain control module (PCM) (12A650) which senses engine oil temperature, PCM voltage and barometric pressure. When the engine oil temperature or the barometric pressure is low, the PCM activates the glow plug relay and the glow plugs. If the PCM voltage is too high, the powertrain control module deactivates the glow plug relay and the glow plugs immediately energize for a shorter duration, decreasing the modulation of the duty cycle.
Glow Plug Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE RED-STRIPED WIRING HARNESS CARRIES 115V DC. SEVERE ELECTRICAL SHOCK MAY BE RECEIVED. DO NOT PIERCE.
    Remove valve cover (6582). Refer to Section 03-01D .
  1. Disconnect glow plug electrical connector using a pair of pliers.
  1. Remove glow plug using 10mm socket.
  1. Clean and inspect glow plug tip for damage. Replace if damaged.
Installation
  1. Install glow plug and tighten to 19 Nm (14 lb-ft).
  1. Connect glow plug electrical connector. Make sure glow plug wiring is routed to avoid moving parts.
Glow Plug Control Glow plugs are used to warm the cylinders to improve cold-engine starting. The PCM uses the engine oil temperature (EOT) sensor and barometric pressure (BARO) sensor to determine how long the glow plugs will be on. The PCM energizes the glow plugs longer if the engine is very cold or if the barometric pressure is low at high altitudes.
The PCM controls the relay that supplies power to the glow plugs with the glow plug control (GPC) signal. When the GPC signal is grounded by the PCM the relay closes, turning the glow plugs on.
The glow plugs are controlled by the following sequence:
  1. PCM energizes the glow plugs.
  1. The PCM energizes the glow plugs immediately after the ignition is placed in the ON position.
  1. The PCM then determines how long glow plugs will be on based on EOT sensor and the BARO sensor. The required time to warm up the cylinder decreases the engine oil temperature and barometric pressure increases at low altitudes.
Glow Plug Lamp Control The glow plug lamp (GPL) signal controls the WAIT TO START light located on the instrument panel. This light is used to indicate when to start the engine. The cylinders are being warmed by the glow plugs during and after this light is lit. The PCM energizes the glow plug lamp longer if the engine is very cold or if the barometric pressure is low.
When the GPL signal is brought low, the "Wait to Start" lamp is turned on.
The glow plug lamp is controlled by the following sequence:
  1. PCM lights the WAIT TO START light after a key on reset occurs.
The PCM determines the glow plug lamp activation time based on engine oil temperature, barometric pressure and battery voltage.
  1. PCM turns off the WAIT TO START light.
The glow plug lamp is turned off when the timer counts to the number of seconds specified by the PCM. The glow plugs will normally remain on longer than the "Wait to Start" lamp.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
