Question about DeLonghi 6707E Oil Filled Radiator Heater
Portable heater I need two parts that can be shiped to 2292285559Dan
  • 22 Answers
Re: portable heater - DeLonghi 6707E Oil Filled Radiator Heater Heaters
Let me know...i can get u parts
Posted on Nov 17, 2007
0 characters
3 Points
I need a manual
email me at I have it in PDF format I will send to you
Nov 29, 2011 | Comfort Zone CZ1500WC Infra-Red...
Does not heat up. Is there a way of opening the radiator?
Oil heaters produce no fumes or flames and feature whisper-quiet operation. Because the oil within the heater never needs to be replaced, oil-filled heaters are maintenance-free. In addition, these types of heaters are compact and portable - allowing you to carry them from room to room. Many also feature carrying handles or a set of casters for easy mobility
some of these types of heaters have a hole with a plug, that allow you to add oil, but few of these are in use today. so this being said it is most likely the heating element is failing to fully heat up the oil. parts may be found, if researched in detail on the net
also be known that the electrical componets are most likely to fail befor the oil evaporates. so look at all overheating controls and so on.
good luck,
Jan 28, 2011 | Patton POH2520-U Oil Filled Radiator...
I need a psr t for my portable forced air heater it's a old one the best I can tell It's a 35/50 70000 BTU/HR. ware would I be able to get parts
You can call Allparts Equipment and Accessories at 1-877-475-5660 they have one of the largest supply of DESA parts still available.
You can also go to
Jan 04, 2011 | Desa International Kerosene Portable...
Need parts for Dayton Ultra Portable Heater Model 1VNX6A I need a source for parts
I would cotact Grainger industrials supplies by callig 1-800-323-0620. Or e-mail at I have dealt with this company for 25 years and I've always been happy to do business with them. Hope this helps you. You will need name brand,part description,and part no. if possible.
Nov 18, 2010 | Dayton E48 Oil Filled Utility Heater
I need a service manual for a Dayton oil fired 350,000 BTU heater.
I have a manual for a Dayton 3E218E. If you want a copy email me at and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well:
Nov 30, 2009 | Dayton E50 Heater
Hi, I need parts for a kerosene torpedo heater.
You need to call Portable Heater Part in Valparasio,in for replacement parts
Oct 07, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Portable kerozene heater
If this is a forced air kerosene heater it does not use a wick. If it is a portable wick heater you can get them for all brands at Portable Heater Parts on the web.
Apr 02, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
PH55 "lawn boy" porta- heater need parts
Lawn Boy sent me an 800 number for the company they sold the heater line to.
800-362-6951 portable heater parts. I have not called yet to find out if they will have qhat I need. Will call tomorrow, Tuesday.
Jan 25, 2009 | Reddy R60A Utility Heater
Pump pressure
throw it away, i have 6 desa heaters that cost me more in maitenance than a new one trow it away and buy a new one
Jan 04, 2009 | Desa International Kerosene Portable...
DeLonghi 6707E Oil Filled Radiator Heater Logo
Top DeLonghi Heaters Experts
Are you a DeLonghi Heater Expert? Answer questions, earn points and help others
