When I turn on the camera (press the power button,) the lense opens, the camera grunts three times, then the lense closes, and the power shuts off. I can still look at pictures on the camera, but I cant take any. I tried to charge the battery and still nothing. The camera says that the battery is fully charged.
I have the same problem and the green light on the top of the camera flashes all the time. The lens comes out then retracts. My camera is less than 4 months old but it was a present and the friend who gave it to me is not contactable right now.I have the same problem and the green light on the top of the camera flashes all the time. The lens comes out then retracts. My camera is less than 4 months old but it was a present and the friend who gave it to me is not contactable right now.
AnonymousMay 26, 2008
Same exact problem. Is this covered underwarranty.Same exact problem. Is this covered underwarranty.
I have the same exact problem. The problem occurred after 2 days of using the camera quite often ( vacation )
I've tried forcing the lens to stay open, but that doesn't seem to work either. I've taken out the battery, Mem card, and even tried turning it on when plugged into the dock on a/c power with no luckI have the same exact problem. The problem occurred after 2 days of using the camera quite often ( vacation )
When I turn the camera on, the lens extends, the camera beeps three or four times, then the lens goes back in and the camera turns off. When I turn the camera on, the lens extends, the camera beeps three or four times, then the lens goes back in and the camera turns off.
when i turn on the camera the lens open it en it close back easily, but i still looking all the pictures that ive taken.. so pls tell me what em i gonna do??? where's the nearest service center here in london??? im desperately wnat my camera back in.. thankswhen i turn on the camera the lens open it en it close back easily, but i still looking all the pictures that ive taken.. so pls tell me what em i gonna do??? where's the nearest service center here in london??? im desperately wnat my camera back in.. thanks
I have the exact same problem, I've tried the hard surface banging and it worked but went straight to the viewing mode and as soon as i pressed any button it switched off again. Now I'm back to the start and i'm too scared about keeping on hitting it against something hard incase i break it even more. What do i do, it's not even my camera AARGH I have the exact same problem, I've tried the hard surface banging and it worked but went straight to the viewing mode and as soon as i pressed any button it switched off again. Now I'm back to the start and i'm too scared about keeping on hitting it against something hard incase i break it even more. What do i do, it's not even my camera AARGH
i have the exact same problem! its really making me mad. its a new camera too.i have the exact same problem! its really making me mad. its a new camera too.
AnonymousAug 17, 2008
Good grief!! I have the ex-z1000 with the exact same problem. I thought it was broken anyway so what the heck, I beat it against the concrete outside twice - works as good as new now!!
Thanks, I was about to throw it out
When I turn on my camera, the lense makes 3 distinctive sounds and is very blurry. I then try to adjust the camera and it powers off.When I turn on my camera, the lense makes 3 distinctive sounds and is very blurry. I then try to adjust the camera and it powers off.
AnonymousSep 09, 2008
when i power up camera to take photos the lens comes out and the camera makes three beeps and then shuts down. i can look at previous pictures but thats allwhen i power up camera to take photos the lens comes out and the camera makes three beeps and then shuts down. i can look at previous pictures but thats all
My camera beeps three times when i try and turn it on then the lens retracts and the camera shuts off. If i push the view button fast enough i can see my pictures for about 1 minute then it shuts off againMy camera beeps three times when i try and turn it on then the lens retracts and the camera shuts off. If i push the view button fast enough i can see my pictures for about 1 minute then it shuts off again
You can't post conmments that contain an email address.
Hey I just tried the banging solution to my EX S770 and it really worked. I did not use the compressed air blow part but I did bang the camera on the bottom on the granite counter top and it working fine. Thanks!
Solution #2 really does work. I couldnt believe it. I just firmly banged the bottom of the camera on the counter 2 or 3 times, hit the power button, and it worked. AMAZING GOOD WORK
I also took off the side panel and sprayed air into it, but I think this solution may work without the air.
First, check if you haven't set the camera for MACRO shoots, if so, only objects very near the lenses are focused. If is not the case you may have drop it and the lens got out of alignment.
Can you see pictures already saved on the camera? If not, the card may be corrupted. Try to format your card if you DO NOT have important pictures on it.
Try playing with the lense I had the same problem. I would turn it on and the screen was frozen, the three beeps then it turned off. I played with the lense since it was sticking out and I tried turning it on again and it worked. :]
no steps yet
