when i turn my computer on i can hear it starting up, but the monitor would say no signal i checked the video card and it still has that same message on the monitor.;
-   Have the same problem. When hooked up via DVI the monitor shows the bios and bootup screen and then says "no signal". I can mess with the power cord and get it to work but it will intermittently say no signal even when showing a signal. Just ordered new DVI dual link cables hopefully that solves the problem.-   hdhaliwal
Jan 05, 2008
-   Acer X241W W / Geforce fx5200 board
I havw the same problem. I get a No signal display in the middle of the screen. I shut the monitor down for a minute then turn it back on-   Guest
As I write to some other question: Run your system in 'Safe Mode'. Go to Display settings and set lowest possible resolution. Then restart computer and run windows again in normal mode. Should have normal screen. If this will not work - then under safe mode uninstall graphic card. Then run windows with standard ones and in LOWEST possible resolution install drivers again. I have had it many times and it made swear first time.
Was this helpful?
Yes
No
Solution #2
posted on Dec 12, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had similar problem. I unplugged power cord to LCD, and re-plugged cord back. It solved the problem. Kind of cold-reset for LCD. I used DVI.
i have the answer .. and it works fine now. i installed a 500watt power supplie to my 2 pcs that had this problem and they are both running on start-up on the first attempt every time.
Mike.
Was this helpful?
Yes
No
Popular Solutions for Acer AL1916W 19" LCD Monitor
I've changed all the setting to Extra Large and nothing happens the fonts are still small in all my...
(More)
I've changed all the setting to Extra Large and nothing happens the fonts are still small in all my program, Simply Accouting and such
