Question about Sharp SD-AT1000H System
Sd-at1000h surround system
I disconnected a speaker and re connected it while the system was on.Despite trying to reset the system with the procedures in the manual it will only come on for a second before switching itself off.Not sure if there is a fix or if worth fixing ?
Any suggestions welcome
Thanks
Stuart
  • 3 more comments
  • Anonymous Feb 26, 2008
    I have basically the same problem, the only difference is that whilst the system was on I moved a speaker, the wire tugged on the power cord which then shut down the system. Now I try to switch it on it will only say "Hello" and shut off. I have tried all suggestions in the manual. Can anyone please help.
    Jonathan P.
  • Anonymous May 12, 2008
    I also have this problem. The first time it happened I sent it back to sharp it was under warranty, however now obviously it isn't and they didn't tell me what they fixed the first time.
    DJ
  • Anonymous May 20, 2008
    I have the same problem. Powers on for 1 sec displaying "hello" and powers off.
  • Anonymous May 30, 2008
    I foolishly turned It on without the speakers connected. Now it comes on for a second , then switches off.
  • Anonymous Aug 08, 2008
    Same problem. Power comes on for one second, display says HELLO, lights come on and fan comes on, and then it dies.
    Nothing in the manual suggests a fix for this. All other fixes in the manual don't work.
    Poor design, will never buy Sharp again.
Posted on Sep 20, 2008
Hi i need your help because i have same problem after high volume.
Did you know guideline to reset it. The guideline in the manuel doesn't work.
Regards
Posted on Nov 05, 2012
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
I have an older LG HT903WA system since new. After reorganising, my rear bluetooth speakers wont connect to the sender. Tried the repairing strategy with no change.
After you reset, all the settings would go back to factory defaults.
Maybe the default settings for the sound in setup are for two speakers only. Maybe you have to go into setup and tell it you've got 5.1 surround (or whatever you have)
Jan 03, 2015 | LG Televison & Video
Only the front speakers work none of the surround speakers
If you are still covered by the warrenty, then you may be able to get it fixed at no cost.
Otherwise get a qualified technician (I say this to cover my but rather than suggesting that you open it up yourself) to open it up and check the fuses inside.
Aug 17, 2009 | Onkyo TX-SR705 Receiver
Not all the speakers are working despite ensuring the cables are
There is a button that says -Mix 2CH - make sure it does not say Mix 2CH ON, or you will only get 2 channels when watching DVDs. This Panasonic, as well as legions of other home theater systems, are more limited than they seem. The SC-HT500 can give you surround when watching DVD's on the unit, but you will not be able to get full surround for your TV, because the Panasonic does not have the right digital inputs.
-Tha Mp3 Doctor
Feb 21, 2009 | Panasonic SC-HT500 System
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Sharp SD-AT1000H
I am having the same problem...the manual says to un-plug the unit for five minutes and then plug it back in to re-set, but that is not working either...
Mar 23, 2008 | Sharp SD-AT1000H System
SCHEMATIC
You can find the service manual in the link below.
SD-AT1000H Service Manual
Mar 13, 2008 | Sharp SD-AT1000H System
Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
May 01, 2007 | Yamaha HTR-5990 Receiver
Sharp SD-AT1000H System Logo
579 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
