Yamata FY700 Mechanical Sewing Machine Logo
A
Anonymous Posted on Feb 03, 2014
Bought a new bobbin case for singer 9410 can not reinstall it so it is not loose how to do
4 Related Answers
Anonymous
  • Posted on Feb 16, 2009
SOURCE: Singer 9410 Bobbin
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Anonymous
  • 1952 Answers
  • Posted on Jul 20, 2009
SOURCE: sewing machine bobbin casing is loose and can't get it back in!
In the lower right hand corner of the bobbin case area, there is a small finger-like spring structure. Gently lift it and push it to the right. Take the bobbin case in hand and inspect it. It is a round piece of metal with a groove running down the edge of it. Now look at the hook, or the round piece of metal that is in the bobbin case area. It has a slight shelf-like structure. Place the bobbin case groove into the shelf-like structure in the hook so as to make it sit flush. With your finger, take the front of the bobbin case and push it to its left so that it is as far counterclockwise as possible and replace the spring.
Hope this helps.
Anonymous
  • 13 Answers
  • Posted on Aug 24, 2009
SOURCE: can't put the plastic bobbin holder back into position
make sure the needle is all the way up and the bobbin is in the case the right way. check to be sure there is no lint or dirt impeding the case. you may have to take out the piece the case fits into to do this. i have found this to be the problem more times than not.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Sep 05, 2011
SOURCE: I inherited a singer model
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 9410 ) & click search
They have a free download,,the second one is free
1helpful
I have a much older model of singer 9410 sewing machine. The feeder is frozen and as I was troubleshooting I took out the bobbin case and cannot get it back in!
First make sure that the bobbin case locking lever is fully back, away from the bobbin case area. This lever is on the left side and to the back of the bobbin area. The bobbin case needs to be put in so the forked end of the bobbin case slides under the feed (towards the needle and the center of the feed dogs). Next slide the front edge of the bobbin case under the position plate. Then turn the lever towards you to lock the bobbin case in place. Make sure that the bobbin case can still move slightly. If it's tight, move the lever again and reset the bobbin case.
For pictures of replacing the bobbin case, see page 39 of the manual. Singer has PDFs of most of their manuals on their support page: https://www.singer.com/support . The current support page for the 9410 is https://www.singer.com/search/support?title=9410 . The current link to the manual is https://res.cloudinary.com/singer-sewing/image/upload/fl_attachment/Singer-Website-Library/outdated_product/SINGER_7029_7033__7035_and_9410_Sewing_Machine.pdf .
I hope this helps.
1helpful
Loading Bobbin Case correctly in a 9410
the machine needs to be checked to see why thats happening
cause the bobbin case isn't suppose to do that
Singer 9410 Bobbin Repair
it sound like the machine needs to be serviced by a sewing machine repair tech
2answers
The bobbin case will not stay in my singer 9410 machine. The case has broken before. I have a new one and I cannot get it to work.
Hi. The position finger on the right hand side needs to be adjusted closer to the case. It may very well be bent. If it is bent, it needs to be repaced.
Singer 9410 bobbin problems
It should not affect the winding, the reason the needle is still going up and down is because the oil has gone dry on the shaft and unless you can get to the shaft where the balance wheel is then it would be wise to take the machine in for a service, loose stitching on the bottom is a tension problem, make sure the top tension is set about 4 or 5
Can't put the plastic bobbin holder back into position
1helpful
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
8helpful
6answers
Singer 9410 Bobbin
Top Yamata Sewing Machines Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
ADMIN Eric
ADMIN Eric
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
