Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Flashes 7 times .
This sony XBR800 will flash 7 times if I try to power it on .
Sometimes if I just leave t off for awhile and plug it in it turns itself on ( I never hit the switch ) and it will do fine .
I am beginning to think it had something to do with it being moved as its a heavy TV and the problems began after that .
  • broncomike1 Feb 17, 2008
    Same problem but my tv has never been moved since we bought it. Left it unplugged for days and still nothing.
There is a regulator Ic8002 that is failing, contact a Sony repairman, you can not do this unless you have the part and know how to solder
Posted on Jan 18, 2008
You may have to resolder the chassis
Posted on Jan 11, 2008
  • 93 Answers
Check power supply regulation and horizontal circuits.
Posted on Oct 25, 2007
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Kdf42-we655 works for awhile then no sound or picture - standby light flashes for awhile then turns to red and flashes in sequences of 5 - then after a short bit tv comes up and works for awhile again. tv...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Red light flashing won't power on
You have 2 good possibilities of what can be causing your problem. The first is the lamp, and the second is the ballast. You would need to be able to use a meter to determine what is wrong. Do you know how?
Oct 28, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KV 36 xbr800
Hiii...
I'm not sure about the chassis number of your tv set..
but I can give a solution for your proble....
It might be the problem at A,B,M board there's no +5V or over voltage +5V...check the IC504 at A board looks like a ic regulator 5V..check c530(470uF/25V),check c540(1000uF/16V)..
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
153 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
