Question about KitchenAid KSRS25IL Side by Side Refrigerator
Kitchen Aide Side by SIde
I just spent $250.00 on a new pc board and my Refridgerator Still won't freeze. The repair man said it was burned out but it seems to be doing the same thing NOT FREEZING?
  • 1 more comment
  • helpfreeze Oct 25, 2007
    Totally, Frustrating!!  The refrigerator guy won't even call me back already cashed check $250.00!  I do not have time to go to small claims and that you know!  I just need to know should I just invest in a new refrigerator?  I have wasted more money in spoiled meats & groceries tan the stupid part.  It seems like when I turn the ting off for awhile (1hour) itresets itself and works for a good 2 hours.  PLEASE HELP!!! I am about to can the whole thing....
  • helpfreeze Oct 26, 2007
    Thank you for all the advice... Well, update I left a message yesterday saying if I didn't hear back in regards to the pc board that I just spent 250.00 on that I would report it.  Well, sure enough the repair man showed up this time with his generator.  He blew air in the hoses and unpluged my refrigerator for about 15 min., the settings are in the middle.  So, this am ice-cream is milky and ice-is frozen, refrigetor room temp.??? Any new suggestions?  Have I run out of options?  Do I need to buy a new refrigerator this weekend (not Kitchen Aid)?
    Thank you!
    One last thing, in regards to my $250.00 pc board for the refrigerator making things worse it seems, the repair man said the compressor is running very warm whatever that is supposed to mean?  I don't know anymore now i am curious if he is just trinying to make money off me.  Maybe I never needed a pc board to begin with?
  • 291 Answers
THe repairman is still responsible for the repair, He didnt fix your refrigertor ans you need to get him to repair it or return you money. Here is a site that may help you find any parts and thing for you to check.
Parts
http://www.partselect.com/MultiModels.aspx?ModelNum=KSRS25IL&searchTerm=img_CD7J3UFE&RefineSearch=0&imgMfg=Whirlpool&Page=2
This site got some pics might give you some ideas
http://groups.msn.com/Appliantology/refrigeratorsampfreezers.msnw
Post if u need some more help go thu the check list and post more ifo
Posted on Oct 25, 2007
  • 1 more comment
  • Mike Johnson
    Mike Johnson Oct 25, 2007
    Things to check
    Check freezer...
    for Frost build up and if Fan is blowing,
    Check condenser...
    To make sure clean, and the fan is blowing by compressor & IF it is running
    Check Recirclating Vents in refrigerator... to make sure theres no blockage,
    CONTROLS ...should be in the middle setting,
  • Mike Johnson
    Mike Johnson Oct 27, 2007
    TO ur question is he trying to make money off me? YES ..They all are...BUT.. IT don't sound like he ever found the problem to start with... IF the compressor is running and ur freezer fan is blowing and the fan by the compressor is blowing... the refrigerator HAS to cool and work ....u have not stated anything was wrong from the check list i posted  there fore I assume everything I posted was checked and ok... the only thing left would be LOW refrigerant.. which would make it a worm bed...
    One way to check to make sure is take off freezer back panel and look at the frost pattern, on evapurator should be light layer of frost, on all the tubes of evaperator, lack of frost some of the tube or tubes indicate low refrigerant ..if low get a new frig.
    PS... stay away from GE when replacing appliances
  • Mike Johnson
    THis is a sample of what to look for... only last few tubes at bottom have frost pattern.. this is a frig with very little refrigerant in it... a leak in the system
Kitchen aide refrigerator no power at compressor dont run
Have you replaced the=> 2154958 Defrost Control Board? Those symptoms are very common for a defective 2154958 Defrost Control Board
Let me know, Thanks JT
Jan 24, 2014 | Whirlpool GS6NBEXR Side by Side...
Water leaking under kitchen aide refrigerator
Could be condensate from the refridgeration unit or the icemaker water connection if the refridgerator has one
Oct 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Kitchen aide frost free refrigerator keeps freezing up.
defrost is not working so you have to check defrost timer,termination switch and heating elements could be any of these
Aug 04, 2009 | GE PSC23NHN Side by Side Refrigerator
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Mar 10, 2009 | Maytag MSD2651 HE Side by Side...
Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Jan 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kitchen aide side-by-side lights are on, but no refrigeration
this a $3-4 thousand dollar refrig, think maybe you should leave this for the service man to check out??? wouldnt want to create any more damage
Jan 16, 2009 | KitchenAid KSSS36QK Side by Side...
Kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 08, 2008 | KitchenAid Dishwashers
Older hobart kitchen aide Supera by hobart KDH7A
If i remember correctly, a KD7 was built in the 70's or early 80's, we used to service them before being sold to Inglis. Seeing it uses the same water solenoids to fill, and asuming it is filling ok, I would suspect worn arms and hubs. If it doesn't fill completely, the fill valve coils may be opening when they get hot from the water flow. The fact that you need a new rack would indicate wear thhoughout and may be too old to justify repair. Find your local Inglis dealer to check on parts availability.
Nov 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
77 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
