Question about SVP CDC-8680 Digital Camera
Camera turns on and then off
The camera will turn on and the shutter opens,the screen says "Digitize your memory"  then it shuts itself down. Help!
  • 2 more comments
  • gsherwood Oct 25, 2007
    Camera is an svp cdc-8680
  • lisharose Dec 27, 2007
    I have tried new batteries, several batteries...It still happens. The cameral turns on and then off.
  • herfish Jan 03, 2008
    h1 same problem takes 1picture ,turns off.i put in the best batteries(AAA) ,sameproblem,every functions are all perfect
  • Anonymous Apr 23, 2009
    aparat w????cza si?? i sam wy????cza pomó?¼cie
Sometimes this happens when the batteries are low. These cameras seem to use up battery power pretty quickly. You might want to try using rechargeable "hybrid" batteries.
Posted on Nov 26, 2007
What is wrong with camera that was working fine and suddenly shutter wont shut and is stuck open?
Take it off of bulb it suppossed to stay open on bulb. Set ISO too 100
Set shutter to 1/60th of a sec. And appuatue to 5.6 then take lens cap off and shoot. Goodluck
Jul 11, 2014 | Pentax Cameras
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
No image was shown on screen while i still can take photo.
According to ehow:
Turn off your Canon 1000D and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
    Black screen when i turn camera on have changed the memory card, menu works and all my pictures are still there when i go to preview on old memory card, have changed the batteries also. Kodak...
    A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
    Dec 19, 2010 | Kodak EasyShare C913 Digital Camera
    Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
    Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
    But if your camera is also taking black pictures,
    a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
    Jul 30, 2009 | Canon PowerShot A620 Digital Camera
    LCD screen is black-cannot take photos
    A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
    Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
    Camera won't stay turned on
    Format the SD memory card.
    Get the 5 volt charger and charge 3 hours.
    Format the internal memory.
    Menu button and change to power save.
    Do not use the flash all the time.
    Vitally
    Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
    The camera won't turn on.
    Did you try taking out the batteries?
    Nov 27, 2008 | Canon PowerShot SX100 IS Digital Camera
    Lens problem
    If you've replaced the batteries with fresh ones, it probably has a broken zoom assembly. It'll have to be replaced by a repair shop.
    Dec 13, 2006 | Canon PowerShot A520 Digital Camera
    SVP CDC-8680 Digital Camera Logo
    66 people viewed this question
    Top SVP Cameras Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Jaime Hernandez
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a SVP Camera Expert? Answer questions, earn points and help others
