Dymo LetraTAG Thermal Label Printer Logo
Posted on Jun 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No ink - Dymo LetraTAG Thermal Label Printer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
226
Points
I changed the batteries and it worked
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Jun 06, 2009
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
21994
Points
181
Unfourtunatley you can't actually get replacement ink for electronic label makers... so you'll have to get a new one sorry...
3answers
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Ink indicator lights
It's mean "ink out". Not actually "inK", but ink level counter reached zero. If using original ink tank, just replace with new one. If using "hardware resetter", reset ink level counter. If using CIS ink tank, it will be auto reset.
Remember, it's program not actual ink. So, if you reset it, ink level will show full, even if you didn't refill ink tank.
Xerox phaser 8500 error code 09, 038, 46:4597
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
4helpful
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
I am getting the following error. 09,038,46:15008
09,038,46:15008
Ink count flag stuck after melting 2.5 Black Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Troubleshooting Procedure
1 Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Yes) Go to Step 2.
No)Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. This must be performed following an ink loader replacement.
2 Test the appropriate Ink Melt Heater. Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
4 = Black
Did the test pass?
Yes) Replace the Printhead
No)Replace the Ink Loader.
Could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
2. Test the appropriate Ink Melt Heater.
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
How do I check my ink levels
Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
Let me know if you have any other questions. Please rate this solution. Thanks.
2helpful
I just put in a new black ink cartridge and it will not print black ink. The color ink prints, but the black will not.
Hello nicfurtaw, there are dried ink on the ink carousel, or cradle, you may need to soften the ink. Use cotton buds, dip into warm water and gently wipe the ink hole where the ink pass through, until the carousel is clean.
  1. remove the black ink cartridge
  2. find the spot where the ink pass through
  3. see dried ink on it.
  4. use cotton buds dipped in warm water to soften the ink.
  5. do this several times
  6. clean enough, test to see if the black ink will pass through
  7. replace the black ink cartridge
  8. test the printer.
2helpful
2answers
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Error: 09,035.43:27650
You have a Cyan ( blue) ink stick stuck or a broken ink stick in the ink loader.
Check the cyan slot carefully, one of the sticks has not moved properly, The machine is not seeing the ink loader moving indicating a stuck cyan stick, Here is the info.
Ink stick count faults (error code 09,03x.4x) are declared when the printer melts 2.5 ink sticks without tripping the color's ink out flag. The ink out flag is used to physically count ink sticks passing thru the ink loader.
Verify that the ink sticks are Xerox 8500/8550 ink sticks. Manually verify that the ink stick are correctly loaded and are able to advance in the ink loader chute. Check for broken ink sticks which can fool the ink out (ink stick counting) sensor.
The ink stick count fault can only be cleared by powering up the printer in internal diagnostics mode. Then scroll and to the Functional menu item Clear ICS Fault.
Top Dymo Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
