Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Frost buildup I have a Kenmore side by side refrigerator. I just noticed that there is frost on the back wall of the freezer and the refrigerator, fresh food section, is not as cold as the setting indicates. Ice Maker is fine but I cannot figure out what the problem could be.
  • 3 more comments
  • carcrazy Nov 16, 2007
    The defrost heater looks ok and seems ok. I melted the frost with a hair dryer and it has been ok for 2 weeks but is now building again. Tried to check the timer but not sure where it is in the fresh food section. I think it may be on the right hand side behind the temp control plastic. Should I turn the screw on that and see if the defrost heater activates? Then turn it back to turn the refreigerator back on?
    Thanks for the help
  • carcrazy Nov 17, 2007
    Melted frost from coils. Refrigerator did turn off but does not appears as thought heater came on. From your comment I should next check the defrost terminator? If so, that is on top of the heater unit? There are alot of wires on the top of the heater. One last question..... If I replace the heater there appears to be 2 parts to the heater within the assembly. Do you know if this comes as one unit when I order? From the parts list it looks like 2 different parts.
    Thank you very much for your help.
  • carcrazy Nov 19, 2007
    Defrost did not come on. Seems like the heater is not too difficulat to replace. I have a parts list but there is a reference part number of 230 that has two different parts listed. My model is a Kenmore 363.50227000 and the defrost ref part is 230 for part nos. wr51x10032 HEATER & BRACKET ASM and wr51X10031 HEATER HARNESS DEF ASM. I assume this is what you meant in that it comes as a kit? Sorry for the quesitons and I thank you very much for your help.
  • carcrazy Nov 27, 2007
    Need help one more time. When I go to www3.sears.com I key in the part number from the original parts list and a selection of 4 parts come up for each part number. I keyed the part number in for WR85x0282 which has a description of LOW SIDE ASM. I selected the first part # for refrigerators and freezers and the part was returned as Evaporator. I selected the other available part with the same number and that description came back as LOW SIDE ASM. This is happening for all the part numbers I key in. How do I know which is the correct one to order?
    Thanks again for all the help.
  • carcrazy Dec 28, 2007
    Have just encountered another problem. The defrost unti I installed seems to be working properly as there is no longer any frost buildup. Now I have just noticed that ice is forming around the water drain at the bottom of the freezer. The drain was completed covered in ice. I melted it yesterday but it seems to be building again. Is the drain clogged? I poured hot water down the drain after melting the ice around it.
    Thanks for the help.
  • 248 Answers
  It is not defrosting.  You have to remove back wall of freezer where frost is and take hairdryer to melt away frost.  You need to check defrost heater.  This is on bottom of evaporator coils.  It has wires going to it on both sides.  This has to be checked for continuity.  If ok on top of coils is a round unit called a defrost terminator.  This needs to be checked for continuity also.  This must be done before you defrost coils.  It should have continuity when its cold.
  If these are ok you probably have a bad timer or defrost board.
Posted on Oct 25, 2007
  • 2 more comments
  • Gerald Griffin
    Gerald Griffin Nov 16, 2007
    Yes. Turn slowly until you hear a loader click. The compressor will turn off. Give it a few minutes to see if the defrost heater comes on. DO-NOT TOUCH HEATER! I use a damp paper towel to touch heater to check. If it now comes on , replace defrost timer.
    If it still doesn't come on, suspect defrost terminator. This is on top of evaporator coils. It is about an inch around with 2 wires. UNPLUG UNIT! Either unplug wires or cut if no connectors. Put the 2 wires together that went to terminator. Not the 2 on terminator. Make sure they don't touch anything. Plug unit in and give a few minutes. If now comes on, replace terminator.
  • Gerald Griffin
    Gerald Griffin Nov 18, 2007
    The heater will come as a kit. Often it will be just one defrost coil in the replacement kit. That's the way they come now. It will come with wiring too.
    Check the defrost terminator first. It is on clamped to top of coils of evaporator. It is about an inch around and about an inch thick.
  • Gerald Griffin
    Gerald Griffin Nov 19, 2007
    I think what you need is the kit. Think it may come with harness and new defrost terminator. If it only comes as 1 heater, it's ok. Just install in bottom location.
  • Gerald Griffin
    Gerald Griffin Nov 27, 2007
    They are all wrong parts.
    You need wr51x10031. This is the heater with harness. Google this part number, can be had elsewhere.
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
I have a Kenmore Modle # 10657206601. The frige side is not cold but the freezer is. Do you have a wiring diag ?
is there frost buildup on the lower back wall in the freezer? defrost control/defrost thermostat/defrost heater. is the compressor not coming on but fan next to it is? compressor start relay. is the fan in the freezer running? evaperator fan motor. those are the most common problems. Greg
Jun 11, 2009 | Kenmore 57029 Side by Side Refrigerator
No cooling
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Side by Side Refrigerator
Check for frost on the back wall of the freezer section. If no frost buildup is noted check that the condenser under the refrigerator behind a removable panel in back is clean and that the fan there operates when the compressor runs.
If you have frost buildup in the freezer section on the back wall you have a defrost system problem. These problems are not related to the cleaning ladies work unless some paper or other item may be stopping the fan from turning.
Jun 11, 2008 | Refrigerators
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
FROST BUILDUP
take the back wall off and thaw unit with either hair dryer, heat gun(very carefully), or boiling water in pan and shut door. You will then have to determine if the def. thermostat, def. control or heater is bad.
Jan 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frost
It has a defrost problem.  1. Defrost thermostat  2. Defrost timer.  3. Or Defrost heater.
Oct 25, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
398 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
