Question about Brother MFC 210C All-In-One InkJet Printer
No printing now
I did have blurry printing now nothing is showing up on the paper    b
  • jbwellington Oct 26, 2007
     I rinserted the new cartridge and it printed once all of a sudden,very light though. Now it won't print at all.    b
    I used brothers ink carts!  How do I clean it?   thanks
  • 832 Answers
Use original brother ink carts and run the cleaning cycle twice! If you do not have any success the printhead is clogged due to generic ink which doesnt consist of the right additives! Sorry, it cant be fixed anymore!
Posted on Oct 26, 2007
  • Mix-it-up
    Mix-it-up Oct 27, 2007
    printhead dryed out. Sorry! No chance to fix it anymore.
Print is blurry. Tried a new cartridge, no help. Will print from 3 computers, but it is blurry. Any ideas?
Depending on the printer, remove the cartridge and then the print head under it. Run it under hot water until the water runs clear. Dry with kitchen towel and the on the computer go to printer properties and run a clean cycle, then run a test pattern. Also check that your paper is dry. Better quality paper produces better quality prints.
Nov 20, 2015 | HP LaserJet M1522nf Multifunction Printer...
Blurry photo print-outs
Hi Ashley
try printing a "nozzle check" and if any colour stripes look incomplete, "clean" or "deep clean" the printhead until you get a good result. You can find the cleaning and test utilities on "Maintenance" page in "Printer properties". Also make sure you're putting the paper in right way up.
Dec 23, 2013 | Canon PIXMA Office Equipment & Supplies
The printer isnt working keeps telling me printing complete
Follow the steps below to fix the problem:
1. Align the print cartridges (open the Lexmark Solution Center on your computer > from the Maintenance tab, click Align to fix blurry edges > click Print) 2. Clean the print cartridge nozzles (open the Lexmark Solution Center on your computer > from the Maintenance tab, click Clean to fix horizontal streaks.) 3. Remove and reinsert the print cartridges. 4. Wipe the print nozzles and contacts using a slightly moistened soft cloth to clean it from dirt or clogs.
Try to print a document again to verify that the problem is fixed.
Oct 22, 2011 | Lexmark Z1420 Printer
My printer is printing blurry lines when im trying to print. grr
Are you using Inkjet paper? or normal office rag? The inkjet paper dosent let the ink soak into it and make lines look blurry, it is amade to dry the ink very fast before it can leak around... Get some good quality "inkjet" paper, you should see better results.
Leave feedback good or bad.
Jan 21, 2010 | Brother DCP-385C Stylish Colour Inkjet...
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Printer is printing blurry
Clean or replace the ink cartridges and select a better print quality from the front panel of the printer.
Jan 03, 2008 | HP Photosmart 2710 All-In-One InkJet...
My printer prints blurry lines!
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge.  if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
Good Luck.
Oct 31, 2007 | Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
108 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
